Hot Rods Trying to fill the rear fender well of my Studebaker M5
Discussion in 'The Hokey Ass Message Board' started by testdepth, Apr 6, 2019.
  1. testdepth
    testdepth
    This truck had racing slicks 28 x 12 x 15 on 15 x 10 wheels that tucked up inside the fender. The slicks sidewalls bulged to 14 inches. Wheels and slicks are gone. I want the same look without the slicks. Or as close as I can come. I think my problem is pushing the tire out to the fender?
    A) mounting surface to first obstruction = 6 3/4
    B) mounting surface to fender edge= 11 1/2
    C) hub dia = 2.47
    D) center of hub to top of caliper x 2 = 13
    E) caliper doesn't protrude past mounting surface
    rotors are 11"
    current tires are 265x70x15
    46814542_10205363500283070_1210478348455641088_n.jpg 48375253_10205408352084337_2001356521149038592_n.jpg
  2. Your rear end is narrowed and the thing is tubbed pretty good.
    You run with that and something from micky Thompson sportsman series tires on team 3 wheels. Should get you close to the same arrangements and sizes.
    Told you the same in your other thread. You'll not get there from the corner tire store.
    Cost you around 2000 all said and done ordering exactly what you need in new stuff. Hunt the swap meets for used stuff you can make work.
    Also take a look at trick 8 wheels. Probably won't be enough but look and measure anyways
    testdepth likes this.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    To bad the wheels are gone now. To have taken specs from them before hand would have helped you now.
    testdepth and Frankie47 like this.
  4. swade41
    swade41
    from Buffalo,NY
    How's the backspacing look on the current rim/tire ? It shouldn't be to hard to figure out just add/subtract backspacing and offset on the current rims, you already know the tire dimension and rim width that worked before.
    testdepth and fastcar1953 like this.
  5. testdepth
    testdepth
    Previous back space was 3.5".
