I am trying to find the correct driven gear for my AOD transmission, the necessary info is below. The tire size: 215/70-15 Ring and Pinion Ratio: 3.89:1 The only thing that I do not know is the exact tooth count on the inside gear but I know that it is either 7 or 8 The transmission that I have is this one: https://transmissioncenter.net/shop...-3-dominator-junior-dominator-junior-extreme/ Which one should I but what gear count ? or where should I start ?
You already asked in a separate post and we responded with sites there. They are inexpensive enough and easy enough to replace, buy one of each... https://www.jalopyjournal.com/forum...-tooth-count-for-my-aod-transmission.1313476/
with my rear end ratio/ tire size, i couldnt get any closer than about 5 mph off with the gear changes. So i gave in and bought a the smallest GPS i could find.
There is a company in Texas (Texas Industrial Electric) that makes conversion “transmissions” adapter. They are easy to calculate if you your city uses those speed mph checkers you can drive by. I use one with a 90* off a T-Bird. I’ve used one for 5 years with the speedometer correct at any speed.
