Trying to fit an inline 292 into a '29 ford
Discussion in 'The Hokey Ass Message Board' started by Eastpunk, Aug 7, 2011.
  1. Eastpunk
    Eastpunk
    Ok- I'm on the tail end of building my inline 292, and I'm at a point where I need to start thinking about getting a chassis put together for my '29 ford.
    Can anyone tell me what kind of clearance issues i will be messing with?
    Specifically- the block looks pretty long, and I'm worried about pushing the bell back into things or having to move the transmission mount back... Of course I could always move the mounts forward if there is enough room left for the fan/trans cooler?
    Anyhoo- I know there are peeps here who have wedged 292's into places where they shouldn't go! What am I getting myself into?
    Any insight would be helpful, thanks!
  2. Normbc9
    Normbc9
    I have two 292 Chevy's in '31 and a '32 Chevy sedan and they fit right in. I did use a later running gear. I still have a Model A and it has a Ford 300 six in it. With some planning and after market motor mounts it will go in. You shouldn't have to do any firewall cutting. But you may have to eliminate the fan and go to an electric 10 inch fan (either pushing or blowing) with a thermostat to help cool this thing. You will need to get a later 3 or 4 tube radiator too.
    Normbc9
  3. RichFox
    RichFox
    I had a 270 GMC in a 32 Ford coupe. Really cut down on the foot room. Don't think I would do that again.
  4. RobsHemiA
    RobsHemiA
    I have a 292 going into my 'A' pickup . My car is pretty low and I have shortened it to get the proportions right , and I can confirm what Rich said . Foot room in a low car is a problem , and the bellhousing is right in the cab . But hot rods dont have to be comfortable . If your not going to do a big channel you could make it work ok . Just take your time setting it up and you'll be fine .
  5. Stan Back
    Stan Back
    Here's a thought -- If you're putting it on A rails, channeled or not, move the body back the distance you need, 3 or 4 inches, and take that amount out of the section between the door and the wheelwell. Lengthen the hood as needed. The back seat is pretty useless if channeled, with the front seats moved back. This would give a real distinctive, kinda Victoria look and have a lot of people scratching their heads. Maybe someone on here could Photoshop this idea.
  6. aaggie
    aaggie
    If you are making your own frame just add the needed length between the firewall and front crossmember. You will need to make a longer hood if you run one.
  7. RichFox
    RichFox
    I remember a guy added 2 inches to the length of his '32 and used a Plymouth hood. Don't know how much work was involved. But we are talking '50s here. Finding a 32 Plymouth hood may not be all that easy.
