Technical Trying to identify Hurst Shifter 628284 - OEM?
Discussion in 'The Hokey Ass Message Board' started by MrCreosote, Dec 11, 2023.
  1. MrCreosote
    MrCreosote
    from USA
    EDIT: THIS IS WRONG:
    Does not say "Hurst" or "Compe***ion/Plus" - only that 6 digit number.
    It does say "Hurst Compe***ion/Plus" and the 6 digit number
    NOTE: My other "Hurst Mystery Shifter" has nothing on it anywhere (pics a few replies from here)
    I can't find any reference to it on the internet.
    Thee doesn't seem to be an obvious reference site.
    EDIT 2: Both of these shifters were acquired in the lath '60s thru early '70s.
    Also have another "Hurst" shifter which has NO markings on it, just what appears to be a "L" where you'd expect an OEM part number. The shift lever out the bottom have part numbers 2130 and 2131. Nothing on the stick.
    1Nimrod likes this.
  2. mgtstumpy
    mgtstumpy
    I searched Shifter doc (Hurst shifters online) and couldn't locate anything that corresponds with above. All the Hurst shifters I've seen are embossed (Stamped) accordingly. Mr. Gasket or another brand?
    1Nimrod and Deuces like this.
  3. Mr48chev
    This is where we gotta have good photos to be able to do any ID. Meaning that some eyes on here (not mine) know what to look for to pick up the clues as to what the shifter started out at.
    Two levers out the bottom means that it is a 3 speed shifter as 4 speed shifters have 3 levers = 1-2, 3-4 & reverse.
    1Nimrod, Deuces and mgtstumpy like this.
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I've got a four speed shifter that looks like a Hurst, but says nothing on it. I'll take some pictures of it this evening.
    1Nimrod likes this.
  5. theHIGHLANDER
    theHIGHLANDER
  6. MrCreosote
    MrCreosote
    from USA
    I just posted the "numbered mystery"
    Should I put pics of the No-Name? Why not (!) haha
    You can see on the 1st pic an "L" stamped (frankly, it doesn't even look like a properly formed L - more like a "proof mark."
    My other No Name mystery shifter:
    upload_2023-12-11_16-44-31.jpeg upload_2023-12-11_16-44-48.jpeg upload_2023-12-11_16-45-52.jpeg
    1Nimrod and mgtstumpy like this.
  7. Mid 80’s chevy trucks had an o/d 4spd with a shifter that looked a lot like a hurst. I don’t remember the markings but they didn’t have hurst on them
    1Nimrod likes this.
  8. Here’s a knock off that could p*** for a hurst?
    mgtstumpy and High test 63 like this.
  9. DDDenny
    Hurst made a Mystery shifter.
    Ollie overhead likes this.
  10. patsurf
    patsurf
    wasn't that only the 3 spd?
    1Nimrod, loudbang and High test 63 like this.
  11. MrCreosote
    MrCreosote
    from USA
    Both of these were acquired in the early 70's
    1Nimrod likes this.
  12. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I've got two factory shifters from the Chevy truck New Process overdrive transmissions, and they're both Hurst.
    1Nimrod and scotty t like this.
  13. The six digit numbers on Hurst shifters are the serial numbers. Patent # was issued 11-9-1965.
    1Nimrod and MrCreosote like this.
  14. loudbang
    Correct :)
    1Nimrod likes this.
  15. Maybe mine were too? I live in the rust belt so they were probably crusty
  16. 57 Fargo
    57 Fargo
    The Mopar ones had Hurst shifters as well.
    1Nimrod likes this.
  17. In_The_Pink
    In_The_Pink
    You might try using the stamped number(s) on the levers to ID the shifter's original usage: https://4speedconversions-com.3dcartstores.com/hurst_levers.html
    With the fore and aft limit stops, it looks all the world like an aftermarket (not factory) Hurst shifter, and the bolt-on shifter stick (vs. a bayonet style slide-in end) might be a clue, too.
    1Nimrod likes this.
  18. MrCreosote
    MrCreosote
    from USA
    I may be wrong, but I thought I saw a housing stamping that was on the inside!
    If the limit bolts are indicative of aftermarket, then it's just a Hurst commodity - I don't think old aftermarket Hurst's have any premium (or do they?)
    I may call Holly/Hurst back and maybe I can get the guy I talked to - he was doing Hurst support for 30 years so he knows stuff. We talked about OE and AfterM
    I did find 4speedconversions but couldn't find any info on OE versions. Maybe they can identify that 6-digi number.
    1Nimrod likes this.
  19. MCjim
    MCjim
    from soCal
    This may be a Hurst Indy, looks like a Compe***ion+, sold as a universal shifter...
    The Hurst® Indy® Universal 4-speed shifter is an economical kit for freshening up the shifts of your Muncie 4-speed (451/452/453), Borg/Warner T-10 (410) or Richmond Borg/Warner Super T-10 (454) transmissions. Some fit and fabrication maybe necessary with these universal shifters.
    I have one, but don't know where I put it.
    1Nimrod likes this.
  20. Joe H
    Joe H
    Factory installed Hurst shifter did not have the limit stops, the Compe***ion Hurst did.
  21. MrCreosote
    MrCreosote
    from USA
    Great to know! I have 4 I'm IDing but this is the only one with the 6-digit - and it is in the place where the OE manu put their part number. GM had 7 digits and Ford had longer - all the place where this 6-digit is.
    QUESTION: Did Hurst put that 6-digit anywhere else like inside the body? or did they only put it on very early models?
  22. MrCreosote
    MrCreosote
    from USA
    I ***ume you're talking abut my No Name "Mystery" shifter?
  23. In_The_Pink
    In_The_Pink
    Look closer. There is a partial "2" (I think I see one when I enlarge the pic) on the same face as the "L". Straight down from the pivot bushing/hole, though it's very faint.
    1Nimrod likes this.
  24. X38
    X38
    Are Hurst shifters like Corvette engines?
    partsdawg and The Shift Wizard like this.
  25. No. It's Hurst STICKERS that are like Corvette valve covers.
  26. HEATHEN
    HEATHEN
    from SIDNEY, NY
    However, every factory Hurst shifter I've seen has small pilot holes where the shift stops would be. I've drilled out several and added them.
    1Nimrod and a4278v like this.
  27. HEATHEN
    HEATHEN
    from SIDNEY, NY
    20231212_190415.jpg 20231212_190420.jpg Looks every bit like a Hurst, but has no I.D. of any sort.
    1Nimrod likes this.
