tube a arms
Discussion in 'Off Topic Hot Rods & Customs' started by jerryt, Jun 8, 2024.
  1. jerryt
    jerryt
    my 1969 Camaro is fun but I read tube arms helps the handling. Can I use tube an arms with my disc brake setup I have on the car now. I am just trying to upgrade the car to make it handle better and be more fun to drive. It's a big block car that I only drive on the weekend. I guess the cost to actual performance will be the factor. If I have to upgrade with bigger brakes a factory style is more desirable.
    Thanks
    Jerry
  2. alchemy
    alchemy
    If you can actually feel the difference between stamped steel arms and tube arms on your occasional driver, I’ll eat the old arms.
  3. DDDenny
    Might have better luck
    Here:
    https://www.jalopyjournal.com/forum/forums/off-topic-hot-rods-customs.98/
    Johnny Gee likes this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Tube a-arms are like bulimic women. Not a good look.
    427 sleeper, Kerrynzl and vtx1800 like this.
  5. 19Eddy30
    19Eddy30
    from VA
    Tube, Lighter & stronger , Yes can be used with Disc ,, For handling and seeing a big difference in handling ,many, many more upgrades will need to be done,
    Including break upgrade ,Sway-bar, shocks, bushings , sub frame connectors ext !! If Z28 aready handles well for 1969 Camaro but if you're looking for road race modern car handling more than just tuber upper and lower control arms.. Just one Brand Look into Q A1
    Kits 3k plus.
    Op
    Your thread / post will be moved to Off topic tread , Like suggested above
  6. Andy
    Andy
    I think most tubular A arms use plastic bushing. They have a short life next to the decades long life of rubber joints. Most also don’t have a place for the upper stop to hit. I would never replace the stock arms with these bad ideas.
    guthriesmith and SS327 like this.
  7. Anderson
    Anderson
    If they are stock geometry, you wont notice anything significant. But if they are made to work with, and you are using a taller spindle or taller ball joints than factory, then that will change things a lot.
  8. My 56 belair could not be aligned properly, couldn’t get enough caster. I bought tubular uppers that were designed to give more caster. They worked beautifully. If they aren’t designed specifically to improve the geometry they are just for showing off at the car show. In my opinion
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ That’s what offset upper shafts are for.
    scotty t likes this.
  10. Kerrynzl
    Kerrynzl
    Total waste of $$$ if you know what you're doing.
    Geometry is geometry it doesn't care whether it is chrome-moly or stamped steel
    Geometry [arc] is an Imaginary straight line between 2 pivot points.
    If you want to improve handling you need to change the pivot points.
    The best cheap method is the "Shelby Drop" on Fords or the "Guildstrand Mod" on Chevys [the same thing]
    On a Camaro you can re-drill the front pivot holes [like Fords] or better still cut off and relocate the frame horns.
    Here is some Camaro horns
    I had this mod on my Corvette [where the rules required using the original mounting holes , so I didn't touch the holes]
    We also tilted the rear down to induce anti-dive, and it really "plants" the front wheels under hard braking
    How this works is the lower A-Arm arcs vertically and the upper A-Arm arcs rearward [because it is now tilted ]
    This causes the whole upright knuckle to rotate inducing more positive caster Which tries to counteract negative caster forces caused by brake torque.[at the caliper bracket]
    I was slamming the brakes on at 176 mph at a 200 yard marker ,then turning in to a 40 mph hairpin bend
    We've also removed a lot of aftermarket bolt-on **** from a 68 Camaro suspension, and it's lap times went down.
  11. Andy
    Andy
    Fantastic post. Wonderful insight. Best in ages!!!
  12. That was the first thing i tried, actually an offset shaft/arm combo. That didn’t do the deed but global west arms did
    427 sleeper likes this.
  13. 19Eddy30
    19Eddy30
    from VA
    Clever thinking, No redrill , just cut & move !!
  14. swade41
    swade41
    from Buffalo,NY
    Nothing to do with handling but I once put on tubular upper A-arms to gain alternator clearance, worked great.
    427 sleeper and ffr1222k like this.
  15. Kerrynzl
    Kerrynzl
    Thanks for the vote of confidence.
    The internet is full of people that re-invent the wheel with Brake Mods, Steering Mods [R & P conversions] and Suspension mods, that actually make things worse.
    The biggest culprit is some salesman who has the answer to your "worldly problems" sitting on their shelf.
    Usually caused by rubber bushes ..... Urethane is a huge improvement [on my Corvette we used steel bushings with grease zerks]
    You can buy stamped uppers with 5° added positive caster which is needed for power steering conversions
    https://www.cl***icindustries.com/product/tf500245.html
    Offset shafts are generally used for camber correction not caster.
    I would rather relocate the frame horns, you can move them inward [camber], rearward [caster], lower them [dynamic camber] ,and tilt them [anti-dive] all at the same time.
    I prefer the engineering approach to throwing "romantic" hotrod parts at the vehicle.
    Andy likes this.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Got me on the caster vs camber. I read the post to quickly.
    Ever reposition an upper ball joint? I have. It works wonders.
  17. Kerrynzl
    Kerrynzl
    Spacers between the ball joint and A-Arm doesn't change the geometry [it only allows for more clearance under the A-Arm for more "droop" [suspension extension]
    If you use extended upper ball-joints it alters geometry
    In the photo below the pivot point is fixed at the ["Red X"]
    Spacers [blue arrows] do not alter the height of the pivot.
    An extended ball joint [yellow arrow] alters the pivot height / geometry
    The problem with extended ball joints is wheel clearance especially when you want to minimalize scrub radius
    Most Vintage sanctions only allow Plus-One /Minus-One
    [you go up 1" in rim diameter, and down one in tyre profile eg: 70 to 60]
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I’m talking about reworking the hole/mounting holes.
  19. bill gruendeman
    bill gruendeman
    HUGE difference in the quality of after market an arms, qa1, and other name brand might be ok. But No name off shore ones you buy online would NEVER be my choice. I personally don’t like the on a mild car, race car is a different store.
  20. DDDenny
  21. Tubular arms also keep you from having to butcher your stock hard to find arms. :cool:
  22. 427 sleeper
    427 sleeper
    Tubular A-Arm's, from a performance stand point, are the cat's ***. Not so good in the look's department on a Traditional ride, though.
  23. jerryt
    jerryt
    Ok the universe has spoken. Im keeping my old stock an arms. I see what people mean about not a good look. I crawled under my car and thought nope. thanks for all the help. Just needed more voices and opinions.
    Thanks
    jerry
    Kerrynzl and 427 sleeper like this.
