Tube shocks for AV8???
Discussion in 'The Hokey Ass Message Board' started by dsiddons, Jan 12, 2012.
  1. dsiddons
    dsiddons
    from Indiana
    Anyone got a part number or year and make for some tube shocks that will work on my AV8? I have the F 1 shock mounts. Thanks..
  2. thunderbirdesq
    thunderbirdesq
    I used the Pete and Jakes covered units on mine, fit the F1 mount perfectly.
  3. 32 Barn Car
    32 Barn Car
    from Oregon
    Monroe #555002 . 12 3/4 " open , 8 5/8" closed . Tube shock with a cover . Price is about $20 + each .......
  4. walter
    walter
    I went to my local retired mechanic and got his 20 year old Monroe shock book and measured my open and closed then matched that to the book and went to napa and ordered them. Next day picked them up and bolted them in place. Less than $100.for all four.
    Walter
  5. choppedsled
    choppedsled
    from Spokane WA
    What are you using for the lower mount? It can make a big difference in the overall length. Just been there....done that.
  6. dsiddons
    dsiddons
    from Indiana
    It's a bung welded to the axle. I used F1 shocks for a 49' Ford but I had to compress them about 3/4 of the way. The rear will need to be shorter than the front. Some of the shocks I looked at had wrong diameter mounting holes.
  7. dsiddons
    dsiddons
    from Indiana
    That sounds perfect for the rear. Thanks for the part number.
  8. Crankhole
    Crankhole
    Should they be in the middle of their travel when installed?
  9. gashog
    gashog
    Monroe 31000 (NAPA RR94008 gas charged), but it kind of depends on the drop of your axle so you might want to take a look at the whole Monroe catalog.
  10. gashog
    gashog
    Sorry, I forgot to include the Monroe catalog:
