Technical Tubes for Firestone tires
Discussion in 'Traditional Hot Rods' started by deucetruck, Oct 5, 2022.
  1. deucetruck
    deucetruck
    from Missouri
    Hello.
    I'm putting new Firestones on the little truck. Do any of you re-use the tubes or always go with new?
    Thanks.
    Just.dale, guthriesmith and tr_rodder like this.
  2. 4ty
    4ty
    If they're holding air I would reuse them. JMO
    Paul in CT
    Tim likes this.
  3. caprockfabshop
    caprockfabshop
    Curious as to why you need tubes? Only time I run tubes in a bias ply is with wire wheels, and only then if I have concerns about leaks through all the wire holes.
    They'll balance easier and ride better without tubes.
    ~Peter
  4. I reused mine as well, no issues.
    But damn, that truck is right on! Sweet!
  5. Primered Forever
    Primered Forever
    from Joplin,MO
    Roger I didn't use tubes when I ran the Firestones on steel wheels.
  6. deucetruck
    deucetruck
    from Missouri
    Guys, thank for the info and nice comments.
    It says use tubes on the packaging from Coker. Truthfully, I haven't broken down the wheels yet, so I'm only guessing that tubes were used. We'll see.
  7. deucetruck
    deucetruck
    from Missouri
    Thanks, Greg. Great to hear from you. Saw your pictures from the Roc. Nice.
    We just returned from Colorado so missed the show. I guess that isn't such a bad thing. Ha!
  8. Primered Forever
    Primered Forever
    from Joplin,MO
    Yes sir! Nothing wrong with a colorado trip! Next year you should try to make this show! It is awesome!
  9. deucetruck
    deucetruck
    from Missouri
    Yes, I would definitely like to. Our younger son is only 45 minutes from Bartlesville.
    guthriesmith likes this.
  10. Primered Forever
    Primered Forever
    from Joplin,MO
    That would be perfect! The hotel lot is awesome as well.
  11. spanners
    spanners
    I use Cokers tubeless on my HA/GR and after dozens and dozens of runs on the 'strip haven't had an issue. If your valve stems just poke through the rim with no collar, there are tubes. If the stem has a smaller collar it's tubeless. Have a look at late models, most of which are tubeless.
  12. deucetruck
    deucetruck
    from Missouri
    Thank you for the information.
  13. CSPIDY
    CSPIDY
    The Coker cl***ics I’m running have tube type on them
    I’m running them tubeless on 35 Ford wire wheels with no issues
