Technical Tubing for frame
Discussion in 'The Hokey Ass Message Board' started by 62rebel, Oct 18, 2022.
  1. 62rebel
    62rebel
    Looking for ideas concerning the use of sch40 2" steel tube for primary tubes in a roadster ch***is; engine limited to about 400lbs with trans.
    Ned Ludd and dana barlow like this.
  2. PotvinV8
    PotvinV8
    Pipe has no place in ch***is construction. Use DOM tubing.
  3. 62rebel
    62rebel
    Don;t know where you saw "pipe". We use tubing to build driveshafts.
    Hnstray likes this.
  4. dana barlow
    dana barlow
    from Miami Fla.
    Tube frame set up have been used a lot,racecars of many types an hotrod. Tube wall of .125 n up,thicker for big HP with smart "X" cross that that pic dose not have. . Both box tube n round,some times twin tube each side. Lot of designs can be found with a fast hunt. I built a good many racecars with tubing" Seamless tube works well with extra stranght
    firstinsteele, 19Eddy30, Tman and 2 others like this.
  5. AccurateMike
    AccurateMike
    Schedule 40 is pipe. 2" schedule 40 is 2.375" OD and .154" wall. Pipe and tubing are not the same thing. Tubing will be called out by OD and Wall. Pipe is not structural. You want to use DOM (Drawn Over Mandrel) tubing. Mike
  6. 62rebel
    62rebel
    Okay dismiss the sch40 description it's easier than saying 2" .120 DOM.
    Looking at app. a 90-100" overall length with at least three crossmembers probably four and a pair of body mount crossmembers in square tube. Again, it's using an O/T four cylinder with a five speed and tranverse leaf springs both ends. engine package expecting to be set back 12" or more from front cross member.
  7. mohr hp
    mohr hp
    from Georgia
    You claim it's easier than saying DOM, but what you announce to us, is that you're building a ch***is from water pipe.
  8. With all that bracing, you could get away with muffler moly. Or 1.5 x .095 wall DOM.
    Atwater Mike, Tman and 2OLD2FAST like this.
  9. gene-koning
    gene-koning
    Sounds like a bit of overkill for an OT 4 with a 5 speed, unless that 4 cylinder has a power adder like a turbo or supercharger.
    Otherwise it sounds like it might be fun...
    firstinsteele likes this.
  10. Bearing Burner
    Bearing Burner
    from W. MA
    Using square or rectangular tubing will make the attachment of brackets much easier than round tubing construction. Don't use any pipe be it schedule 40 or 80.
    gimpyshotrods likes this.
  11. 62rebel
    62rebel
    I'm in Florida, not West Virginia or North Carolina. That tube I mention is driveshaft stock; not house water pipe. although i have seen a **** ton of water pipe in some old roundy-rounders.... along with rebar. I can see from history where you guys might get them confused.
  12. alanp561
    alanp561
    Retired Boilermaker tube welder here. Pipe is measured ID, tube is measured OD. The same size tube can have any number of wall thicknesses.
    gimpyshotrods, 19Eddy30 and 62rebel like this.
  13. Bearing Burner
    Bearing Burner
    from W. MA
    There is no dimention on pipi that corresponds to the designate diameter
    nominal Od Id
    1 1.315 1.040
    11/2 1.90 1.610
    2 2.375 2.067
  14. 1971BB427
    1971BB427
    from Oregon
    I don't think the guys were getting confused "from history", but rather simply from the terminology you used of "schedule 40", which is always water pipe.
    But now that we've got that out of the way, 2" DOM tube is a great choice, but will make fabrication a bit tougher than rectangle tubing as you'll need to radius all the joints to fit. And brackets will also need to be contoured to fit round tube. Box or rectangle tubing would be a lot easier, and quicker.
    gimpyshotrods and caprockfabshop like this.
  15. 62rebel
    62rebel
    Admittedly rect tube is a damn sight easier to work with. I'm hoping to get by with about eight coped joints in the round tube and the rest will be radiused square or rectangular tube. My last frame was absolute overkill for what I had intended (2" x 4" tube) and was heavier than hell. One guy said I built a nice pickup truck ch***is.....
  16. Clydesdale
    Clydesdale
    Unsure what you asking here?
    You seem set on your 2" round tube main rail ch***is with rectangular tube cross members.
    I sense some p***ive aggression in your replies also? Folks are just trying to understand and help
  17. PotvinV8
    PotvinV8
    IMG_0306.jpg Built one using 1.75" x 0.120 wall tubing and 1.50" center section. Worked great.
    RMR&C, ottoman, twenty8 and 19 others like this.
  18. What most folks do not know or get cornfused by is the fact that yes, TUBING can come in "Pipe" dimensions. We order a lot of it for cages and crossmembers. Just normal mild steel. It IS NOT the same as water pipe which is brittle
    19Eddy30 likes this.
  19. 2OLD2FAST
    2OLD2FAST
    from illinois
    Isn't that normally referred to as mechanical tubing ?
  20. krylon32
    krylon32
    from Nebraska
    For 40+ years I have used 1 1/4, 1 1/2 and 1 3/4 120 wall DOM in the construction of my customer ch***is. It works well in my bender and makes a clean looking ch***is.
    38Chevy454 and Magfiend like this.
  21. Ned Ludd
    Ned Ludd
    Intention is not a physical property. There is no fundamental difference between pipe and tubing, only a formal difference in specifying convention.
    Ø2" pipe is Ø2.375" x 0.154" tubing. That doesn't tell you what kind of tubing it is. It doesn't tell you what kind of pipe it is either. If, however, you know the exact dimensions, material, and manufacturing process, you can calculate what the thing could be good for as pipe or tubing or anything else, without any reference to intention at all. All it is is a certain m*** of material shaped in a certain way.
    Pipe has beam strength, compressive strength, tensile strength, just like tubing, and not necessarily any less. Tubing has pressure burst strength, just like pipe, and not necessarily any less. The way some are talking you'd think that you could knot heavy pressure pipe by hand, or pop structural tubing like a balloon.
  22. Dan Timberlake
    Dan Timberlake
    I bought a tubing notcher from Norther Tool about 20 years ago.
    It looks like this-
    https://www.northerntool.com/shop/tools/product_200659540_200659540
    I've only used it a few times, but it works slick on tubing and pipe.
    Some hole saws have co****r teeth than others and axial runout so very few teeth touch at once.
    Noise and vibration is the result.
    I may get a diamond grit hole saw the next time I do any notching. Some but not all say OK for metal/steel.
  23. 62rebel
    62rebel
    NOW we're talking. That's a fantastic looking setup; I have been playing with torsion bar ideas as well... those are neat as hell right there
    PotvinV8 likes this.
  24. Mr48chev
    A lot of the circle track racers use the 1.75 x 0.120 wall tubing for their roll cages. If you know some local racers you might ask where they are getting the tubing for their roll cages.
    High test 63 and 62rebel like this.
  25. kasselyn29
    kasselyn29
    Dude Nice work!
  26. Hot snot. That's the ticket right there. Simple, light, strong. Very nice. Shame to cover it with a body.
    PotvinV8 and 62rebel like this.
  27. That tube ch***is by PotvinV8 is sweet looking for sure.
    I'd be interested in hearing how well that rear driven alternator works. I had a '71 340 Duster many years ago, at one point the alternator, which charged beautifully at highway speed, failed to charge at idle ... I found out when I needed a boost after "cruising the main". I just can't imagine it'll charge enough when looking at the big picture ... that being said, I have no idea what the intended use is for the vehicle :) I just can't see it working for me, too much stop and go traffic where I live.
  28. PotvinV8
    PotvinV8
    Guys, thanks for the kind words!
    The alternator mount is definetely not ideal, but unfortunately the only solution as there's no way to drive it off the engine. The plan is to run two deep cycle batteries to make up for the idle/no charge situation. The guys at Powermaster and XS Batteries are working with me on the project and that's what we came up with. Finger's crossed!
    RMR&C, borntoloze, rod1 and 3 others like this.
  29. DDDenny
    Yes, and it has more curves than Rachel Welch!
  30. Fordors
    Fordors
    I don’t know about parts availability but have you considered driving the alternator off the rear cover of the blower? Instead of a pump the drive shaft on the gear could spin a pulley for the alternator. Potvin and others made drives like this. Or maybe lack of space is an issue.
    rod1 likes this.
