tubing tech question
Discussion in 'HA/GR' started by moparsled, Apr 23, 2008.
  1. last year when I started gathering stuff for my build, I spent a bunch of time reading and researching what tube to buy to build my cage/ch***is. I ended up buying a stick of 1.75" mild steel plain ol' seamed tube, which at the time I thought was an informed choice. A month or so I showed a guy my build and he told me not to run the seamed tube, saying that in the event of a crash the seam will split, the tube will crush, and I'll get hurt for sure.
    I'm getting closer to ready to build the ch***is, do I need to rethink and re-buy, or is this guy full of it? (or thinking way faster than I'll be going maybe?)
  2. ThingyM
    ThingyM
    It won't happen. Believe me..Ive seen many cars that have run that tubeing.. It wont split open or crush as this person has told you.. It's true, Seamless DOM tube is stronger, But in the case of the HAMB cars. Use what you got. We aren't running 7 sec. cars.or 150mph..
  3. QQMOON
    QQMOON
    Molly is your friend ...............
  4. 2b-banjo
    2b-banjo
    What is the wall thickness of the seamed tubing??? I believe also that if the wall is sufficient that you won't have a problem.
  5. QQMOON
    QQMOON
    I dont know but you only have one life and you need to protect it at any cost
    QQ
  6. Old6rodder
    Old6rodder
    from SoCal
    QQMoon's right, if it's going to eat at your mind buy the moly, you'll be more comfortable. Also you'll need to tig it.
    We run seamed .125". Personally I've never seen it split and am quite comfortable with it. And you can mig it.
    Sorry, that .110" can't be right. I'll look up what we bought this evening. Corrected.
  7. bobw
    bobw
    2008 NHRA rule book calls for 1 3/4" dia., .118" wall mild steel tubing. Does not specify DOM. This is for a roll bar, not a cage. Cage hoops can use a smaller diameter tubing. Places like Chris Alston Ch***isworks sell mild steel roll bar and cage kits with .133" wall. This is because .125 wall can sometimes be thinner than .118" or can thin out slightly in the radii when bent. There are mild steel ch***is kits for 7.50 sec. cars so it must be strong enough.
  8. 1934coupe
    1934coupe
    Bobw is absolutely correct. I have built many a roll bar and cage and the 1-3/4"x.118 wall is what is called for but they sell .134 wall because as bobw says it thins at the bend and would not p*** NHRA tech. For a street rod or occasional strip car going 10.99 or slower only a roll bar is required. But its your head!
  9. thanks for the clarifications guys, I'm gonna run what I have.
  10. 64 DODGE 440
    64 DODGE 440
    from so cal
    And quite a nice l*** too!!:D
  11. ocfab
    ocfab
