Technical Tudor gas door
Discussion in 'Traditional Hot Rods' started by chiro, Dec 18, 2013.
  1. chiro
    chiro
    I would rather not have a pipe and gas cap sticking out the side of my Tudor. Anybody put a flush mount gas door on their Tudor that can give me some technical advise and pics on?
    Thanks,
    Andy
  2. lukescoupe
    lukescoupe
    from oklahoma
    Their not my favorite, you have to be careful when you open and shut the door or you will chip your paint. When your out and about people like to walk by your car and push the door and open it for some reason. The flat ones seem to work better than the curved ones.
  3. 40Standard
    40Standard
    from Indy
    are you running fenders? you could run saddle tanks
  4. chiro
    chiro
    I was thinking about something less "street rod" than those. More along the lines of stick gas doors from the '50's or '60's. You know those doors. Every car had them on the quarter panels with the little finger pull stamped into the door. Anybody put one of those on the side of their Tudor? Pics? Technical advise?
    Thanks,
    Andy
  5. olskool34
    olskool34
    A late 40's gm would have a nice flat door and it would probably also have a really nice piece of stainless trim with it also. Go to a junkyard and cut the panel out. I think it would be fairly easy to do.
  6. GregCT.
    GregCT.
    from CT.
    The car I had was pretty cool. A Hagan door that you had to look for with a tank under the back seat. You push in on the door and it springs open and push to close. Like the doors on stereo cabinets and computers.
  7. 32rustedinpiece
    32rustedinpiece
    hey thats my old car... :) only problem with the hagan door was when i welded it in.... it didnt have the right contour, and it buckled the whole back panel. was a pain in the **** getting it back to the original shape. lesson learned!
  8. john worden
    john worden
    from iowa
    Does the "side of my tudor" mean the the body or fender? What year and make is the car? Is it a Ford Tudor? Questions with specific details are easier to answer.
  9. motoandy
    motoandy
    from MB, SC
    liked mine and worked good. Not flush mount though. Off a early's 60's chevy truck.
  10. chiro
    chiro
    '30-'31 Model A Tudor. Side of body. Fenderless. Get it?
  11. Mr48chev
    No need to get your undies in a wad, ***uming that everyone on here knows that you have a 30/31 Tudor is ***uming a lot.
    Before the Hagen an some of the other aftermarket came out with their doors we just went to the junk yard and found a gas door the right size in the right shape (curve or no curve) panel and cut it out and took it home and trimmed it to fit. I keep eyeballing the gas door on my 92 Geo Prism GSI as it is small flat and operates with a pull cable from beside the seat. Dodge mini vans also have a fairly flat gas door that is cable operated.
  12. On my 26 T Tudor, I used what I could find...a 1968 VW gas filler door and tube, photos if you want....
  13. john worden
    john worden
    from iowa
    Got it. Looks like 3 choices.
    1 Cut a panel including the door, hinge and opening from a doner car and weld
    the ***embly into your body. Down side is warpage from several inches of
    weld.
    2 Remove and use the hinge from a doner, make a door and cut the opening to
    fit. Down side is fab time.
    3 Remove and use hinge and door from doner, cut opening to fit. May be best choice. Minimum fab and welding.
