Projects Tudorfritz slowly builds a Model A (build thread)
Discussion in 'The Hokey Ass Message Board' started by tudorfritz, Dec 20, 2009.
  1. ImageUploadedByTJJ1329177233.143730.jpg Finished product, I'm going to paint the radiator black and make a grille out of stainless mesh that will also be painted black. There will also be a fan shroud that will cover the back side of the radiator.
  2. ImageUploadedByTJJ1329179850.835561.jpg I also finished up the sub rails that are over top the gas tank.
  3. ImageUploadedByTJJ1329684603.769977.jpg . The floors are done with the exception of the access doors for the fuel sending unit and roll over vent.
  4. ImageUploadedByTJJ1329684819.025552.jpg Gonna tape it up now and spray some epoxy on it.
    Got the car all primed and somewhat put together for the show this weekend.
  6. View attachment 1579031
    I know it's a ****ty picture, but I made a grill to protect and help hide the radiator. The frame is 16ga stainless and the mesh is also stainless. The whole ***embly bolts between the radiator and the shell.
    Can't even tell there's an aluminum radiator hiding in there.
  9. shep_911
    shep_911
    sweet looking ride
    Thanks man, this is how it looks as of now. I took it to the Cavalcade of Cars show this weekend. Pretty pumped to get this thing done now.
    Oh yea I forgot to mention the car won "best traditional hot rod". Got this bad *** trophy made by Paul Straus. Just want to say thanks to all the guys who made this happen.
    kiwijeff likes this.
  12. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    It looks great! Ya got skills, that's for sure!
  13. Thanks, gonna start tearing the car apart tonight so I can finish welding the underside of the body and frame. Next body work and paint.
  14. sk8erdave
    sk8erdave
    Ive just gone through this thread and your car is great. Its how I would build an A sedan if
    a, I had the skills
    b,had the money
    The stance is spot on.
  15. Brads MONSTER
    Brads MONSTER
    from Buford GA
    i have heard a lot of people talk about bulding a car like you but they are all talk you made it happen!!! BAD *** BUILD
  16. Thanks guys, nothing new to report. Gonna start on the rain gutters tonight and I'm still waiting for my Navarro heads to come in.
  17. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I'm really liking the rollbar setup under the cowl. Going to try to incorporate something similar in mine as well, thanks for the inspiration!
  18. Haven't worked on the car in almost 1 1/2 years. Good news is no more working in a small 2 car garage. My wife and I sold our house, bought a acre of land and built a new house and 40'x40' pole barn. Now that the barn is done and the house stuff is done for now I'm back on the car. ImageUploadedByH.A.M.B.1376516334.804950.jpg
  19. Started tying up some loose ends on the front suspension. I added another tab for the lower shock mount on the wishbone. Since I cut the bones to set the caster and with all our ****ty roads I added a small gusset to the bottom for a little extra strength. ImageUploadedByH.A.M.B.1376516753.324444.jpg
  20. I also added a steering dampener. I figure it couldn't hurt having one especially with the cowl steering. I cut the end off the dampener and welded a rod end to it and welded a tab to the wishbone. It's a tight fit and not too noticeable and everything clears. ImageUploadedByH.A.M.B.1376517056.599502.jpg ImageUploadedByH.A.M.B.1376517085.452391.jpg ImageUploadedByH.A.M.B.1376517127.737000.jpg
  21. gordspeed
    gordspeed
    from Oregon
    I would have taken a break too, for a shop like that! Nice build!...... Now get back to the car!! :)
  22. Got a few more things done. With the wheels turned full lock to the left the tire would rub on the steering arm. So I made a small ****on that I welded to the back of the spindle. ImageUploadedByH.A.M.B.1376611649.825536.jpg ImageUploadedByH.A.M.B.1376611666.245476.jpg ImageUploadedByH.A.M.B.1376611688.358798.jpg
  23. There was a small amount of flex in the steering box mount. Since the box only has three mounting bolts and they are all on one end of the box. I added a diagonal tube to the bottom of the box mount. And I made a small tab to bolt the other end of the box down. I know it looks really tight, but every thing clears with no problem. ImageUploadedByH.A.M.B.1376612214.702148.jpg ImageUploadedByH.A.M.B.1376612243.728683.jpg ImageUploadedByH.A.M.B.1376612263.544026.jpg
  24. HotRod33
    HotRod33
    Looks like the new shop is great and now your making progress on the hotrods again...
  25. Thanks, its slow going but I try and work on it every night. I usually don't get out in the shop until 8:30 when my son goes to bed.
    Got some eye candy in the mail today.
  27. ImageUploadedByH.A.M.B.1377134452.419346.jpg ImageUploadedByH.A.M.B.1377134478.035780.jpg
  28. I finished up the steering box frame. The pedals, master cylinders, and fuse box will also be mounted to it too. I put 18 small tabs on it so the kick panels and firewall panel will have a place to mount to. ImageUploadedByH.A.M.B.1377223034.620355.jpg ImageUploadedByH.A.M.B.1377223063.320651.jpg
  29. mws
    mws
    from Iowa
    Awesome craftsmanship!!
  30. Thank you, gonna try and get the steering box frame painted today. If I can sneak it in the booth.
