Projects Tudorfritz slowly builds a Model A (build thread)
Discussion in 'The Hokey Ass Message Board' started by tudorfritz, Dec 20, 2009.
  1. rfritz
    rfritz
    from New York
    I wish I had a quarter of your talent
  2. Ha, thanks Uncle Bob.
  3. crminal
    crminal
    First look at this . Well done!
    I really like the flanged/riveted firewall recess.
  4. Thank you, I got the first part painted. The steering column will be painted gloss black also. I take small parts to work with me a few at a time and paint them during my lunch break. I'm gonna have the clutch/brake pedal arms chrome plated also. ImageUploadedByH.A.M.B.1377386284.786964.jpg
  5. Just got the body off the frame. Gotta finish up welding the frame then its off to the blaster for a clean up. ImageUploadedByH.A.M.B.1377918479.585410.jpg ImageUploadedByH.A.M.B.1377918541.666467.jpg ImageUploadedByH.A.M.B.1377918567.775271.jpg
  6. ty johnson
    ty johnson
    Looks great! Not sure how you get anything done working in that mess though.
    LOL
    Nice shop!
  7. It's tough but I try to just work through the filth. LOL
  8. Lukydevl
    Lukydevl
    from Arizona
    Horrible working conditions!!!
  9. ImageUploadedByH.A.M.B.1378425842.205190.jpg ImageUploadedByH.A.M.B.1378425856.662095.jpg ImageUploadedByH.A.M.B.1378425877.247820.jpg
    I'm pretty much done with the welding on the frame. I had a hard time pulling the body off the frame because the rear rails are a touch wide. Not to mention i did it by my self with a floor jack and 8 jack stands. So I tapered the rear frame rail ends to make it easer when I put the body back on. I pie cut the rails back 4" then welded them back together. Also capped the ends of the rails and the two rear suspension mounts.
  10. thunderbirdesq
    thunderbirdesq
  11. JM53
    JM53
    from Round Rock
    Great work! Im in the middle of a 29 A Roadster build. Gave me some ideas for the floor.
  12. pastorbc
    pastorbc
    from kentucky
    I think I have 1/4 of his talent, so I guess you wish you were me!
  13. critchdizzle
    critchdizzle
    from Owasso, OK
    Wow. Looking great. Subscribed!
  14. Thanks Andy, I'm no Brian B*** that's for sure.
  15. Ha ha, I'll make sure I tell him.
    Thanks guys, gonna drop the frame off at the blasters Monday after work. Hope to have the frame, axles, and a lot of other small stuff painted in the next couple weeks.
  16. Since the frame is at the blasters I started working on the seat. I want to get seat built and all the mounts made before I start doing bodywork and paint. I got a 3rd row seat out of a junk mini van at work for free. I peeled the seat cover off the foam and cut 5" out of the seat bottom frame and foam. I had to notch the bottom of the seat back also to fit over the tunnel. Still got to figure out how I'm going to mount it all and gotta do some more work on the frames. So far it fits pretty good and is comfortable. The foam will be smoothed out and I'll have it covered in leather tuck n roll. ImageUploadedByH.A.M.B.1378867729.541128.jpg ImageUploadedByH.A.M.B.1378867753.285124.jpg ImageUploadedByH.A.M.B.1378867771.496739.jpg
  17. thunderbirdesq
    thunderbirdesq
  18. Got the frame back from the blasters last Friday. I epoxied it Friday night and the next day started doing bodywork to the outer original frame rails. They were pretty pitted up from rust, but a skim coat of mud fixed that. Just primed the rails tonight and plan on painting the frame, axles, and a bunch of other parts on Saturday. ImageUploadedByH.A.M.B.1379558779.619721.jpg
  19. Well I couldn't wait till today to do some painting. I went back to work at 8:30 Friday night. Finished up spraying at 1:00 am. ImageUploadedByH.A.M.B.1379796078.323261.jpg ImageUploadedByH.A.M.B.1379796095.584111.jpg ImageUploadedByH.A.M.B.1379796119.408975.jpg ImageUploadedByH.A.M.B.1379796131.402733.jpg
  20. Lupe.
    Lupe.
    from TX
    I see you have access to a down draft booth. Nice. Parts came out real nice. I'm still getting used to the single stage ch***is paint myself. It's hot as hell here in Texas.
    Great build. I've been going through your pics over and over. Got lots of ideas from.
    Thanks!
    -Lupe
  21. Thanks Lupe, yea my boss is pretty cool about letting me use the shop after hours. Plus it helps I only live 2 miles from my work so its easy to come and go while working on my own stuff. I actually used base clear on all the parts including the frame. I have most of the ch***is ***embled now and will be rolling by the weekend.
  22. I bought the complete front brake setup from a guy that was replacing them with disk brakes. I'm not sure what the hubs are but something is not right with the setup. I didn't want to find different hubs since they already fit my wheels and everything fits pretty well. Problem is 3/16" of the brake shoe was not inside the drum. I figure the easiest way to fix it was to make a 3/16" shim to move the backing plate into the drum more.
    First I had to trim off 3/16" off the lip of the backing plate. It was too big to fit in my lathe, so I mounted it on my rotary table in my mill. (This was before I painted them) ImageUploadedByH.A.M.B.1380165128.049685.jpg
  24. I made the shim out of 3/16" plate steel. I cut the outside shape with my bandsaw, and used my mill to make the inner hole.
    I just made the shims tonight so I'll take them to work tomorrow and paint them and bolt them up for good tomorrow night. All bolted up the shims are hardly noticeable. ImageUploadedByH.A.M.B.1380165704.848375.jpg
    I still have to fix a couple of broken fins on the drums. Then I'll true them up and blast them to clean them up.
  25. ImageUploadedByH.A.M.B.1380166009.490419.jpg ImageUploadedByH.A.M.B.1380166039.350791.jpg ImageUploadedByH.A.M.B.1380166053.026865.jpg
    kiwijeff likes this.
  26. Lukydevl
    Lukydevl
    from Arizona
    Very nice work!!!
  27. ImageUploadedByH.A.M.B.1380326486.785569.jpg ImageUploadedByH.A.M.B.1380326499.239744.jpg ImageUploadedByH.A.M.B.1380326511.138961.jpg
    Try this again
    I tore the motor down so I can check it over and paint it. I've been collecting motor parts too. I got new Bob Drake water pumps, Navarro heads, and a mellower cam for the street. ImageUploadedByH.A.M.B.1384900721.903570.jpg
  29. I also had to make a new base for the dip stick in the oil pan. ImageUploadedByH.A.M.B.1384900828.779401.jpg
