Tunnel Ram Carb Help
Discussion in 'Off Topic Hot Rods & Customs' started by AldeanFan, Jul 19, 2026.
  1. AldeanFan
    AldeanFan
    Need some help from the HAMB wisdom.
    I have carburetors where fuel flow is intermittent from the boosters.
    I’m not a carburetor expert at all but trying to help a friend.
    He has a 383 SBC with a dual quad Tunnel ram that won’t run well.
    Ignition is spot on and everything is new and working fine.
    I’ve checked fuel pressure, float levels and it idles pretty good.
    The problem is that when you open the throttle sometimes fuel pours out the boosters and sometimes no fuel comes out.
    I’ve never seen one this inconsistent.
    About 50% of the time there is no fuel.
  2. lostone
    lostone
    from kansas
    Do you have a fuel pressure gauge so you can see what the fuel pressure is doing ?
    Also helps to know what carbs, edelbrocks don't like more than 5, holley will handle a little more.
    Also what kind of fuel pump ? Mechanical or electric and it's specs...
    GlassThamesDoug likes this.
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    Look up the term "reversion" . Might explain the problem
    RMcCulley likes this.
  4. AldeanFan
    AldeanFan
    Awe
    have a fuel pressure gauge and it is steady at 8psi and drops to 7 at wide open.
    It’s a Holley electric pump.
    I don’t know the carb numbers but they are Holleys
  5. 2OLD2FAST
    2OLD2FAST
    from illinois
    Turn the fuel pressure down ...6 psi is plenty
  6. AldeanFan
    AldeanFan
    I agree, we need a different regulator however,
    And I don’t think that too much fuel pressure would cause no fuel in the carburetors
  7. AldeanFan
    AldeanFan
  8. Fordors
    Fordors
    Those look like 4224 center squirters, 660 CFM. You mentioned sometimes not seeing fuel from “the boosters”, are you referring to the accelerator pump nozzles or the venturi boosters? The nozzles should give a shot of fuel as soon as you move the throttle. The boosters will show flow as rpm climbs and the venturi action pulls fuel from the float bowls.
  9. 19Eddy30
    19Eddy30
    from VA
    IMG_5760.jpeg Check that gauge to see reading correct. Not to many small ones read correct in last 20 yrs.
    5-6 psi is enough from known good accurate gauge .
    you say some times fuel leaks some time then Not ,
    sounds like talking about
    Squirter.
    yellow circle's
    check accelerator pump cam adjustment
    No play will push fuel out of squirter's.
    About .040 -- .070 gap needed .
    Bad float Needle seats can not move freely & stick most time will cause flooding
  10. AldeanFan
    AldeanFan
    The squirters and accelerator pumps are adjusted correctly, I spent the afternoon adjusting the accelerator pump linkages and swapping pump cams trying to get rid of an intermittent bog.
    once I got the squirters working properly I noticed that about half the time fuel isn’t coming out of the boosters.
    After staying up late reading, I’m concerned that the combination of the tunnel ram and the camshaft are causing not enough air flow to pull fuel from the boosters.
  11. 19Eddy30
    19Eddy30
    from VA
    I see Stalh pattern headers
    More spec on engine .
    Vac # @ idle
    Idle RPM's
    Plugs
    Converter or stick .
    Compression
    What Fuel grade # using
    Octane matters to how tune engine
    where the timing set
    15-20 btdc , some need more @ base .
    What's the Total .
    Fuel out of booster's when ?
    @ Idle
    Or
    After transfer slot into cruise & WOT .
    No fuel should come out booster's @
    Idle .
    Carbs
    are they stock from box or have been changed around beside cam squirters .
    Are the carbs center squirter's.
    Have you looked to see where ****erflies are set in relation to transfer slot's ?
    Disconnect the secondary ,
    Go from there
    try to help diagnose issue
    & where to start changing .
  12. GlassThamesDoug
    GlassThamesDoug
    Stock 4224 carbs are designed for Tunnel rams.
    Float Level, needle and seats. Sticky needles... can cause. These are very responsive carbs.
    Tickety Boo likes this.
  13. onetrickpony
    onetrickpony
    from Texas
    IMHO, 4224 carbs were designed for wide open throttle performance and not for part throttle response. The were designed for manual transmission, low gears, and lots of flow (heads and cam). If that doesn't describe your friend's car, I'd advise swapping to vacuum secondary carbs.
  14. AldeanFan
    AldeanFan
    It’s in a nostalgia drag car with 5.13 gears and a power glide with a loose converter and a manual valvebody so it should be ok for the purpose.
    It’s jut not giving fuel consistently.
    Tickety Boo and SS327 like this.
  15. 19Eddy30
    19Eddy30
    from VA
    Loose converter
    4k
    5k
    Is there 2 step or throttle stop ?
    off ****on should be p*** idle circuit
    & cam shot .
    Have you verified fuel psi & delivery
    is there alot of br*** fittings ,
    Mention again the gauge shown notbto many are good & accurate ..
    Where the fuel tank
    Front
    Or rear
    type fuel pump
    Just to Mention fan Not recommended over 6 k rpms
