Tunnel ram pic request
Discussion in 'The Hokey Ass Message Board' started by junkyardkat, Nov 15, 2009.
  1. junkyardkat
    junkyardkat
    Hi all, need some ideas on tunnel ram linkage mounting, mainly cable that goes to trans on a turbo 350, I will be using a holley on a wiend single 4 tunnel ram. thanks
  2. Pontiac Slim
    Pontiac Slim
    If you mean a cable to activate p***ing gear... I'm running a t-ram with a turbo 400 with no downshift cable
    Pontiac Slim
  3. Gator
    Gator
    from Statham Ga
    Why would it be any different than the stock setup if you're using a single carb?
  4. junkyardkat
    junkyardkat
    the p***ing cable is to short to to be mounted to brkt on the carb.
  5. Screamin' Metal
    Screamin' Metal
    from Oklahoma
    Dawm! Pontiac Slim! Howdy BRO! Just started My tunnelramed 421 superduty aluminumed frontended Drag Catalina yesterday, backfired thru the intake and blew off the top of the aircleaner on the front carb!
    Now....since I'm settling down now....let me ask you this........why the hell would you want to hook up your p***ing gear on a TH-350? You don't need it, all it does is 1. kick up your pressure in your valvebody,2.does the same thing YOU OUGHT TO DO WHEN YOU ROMP ON IT, SHIFT IT MANUALLY. You really don't want to be dragracin' in drive.........
  6. Pontiac Slim
    Pontiac Slim
    Hey.. I'm do'n fair to down right piss poor (heavy on the poor side LOL)
    Hell I never knew I even needed a downshift/whatsever in my 455 hee hee.. lets see right foot plant to floor, two hands on the steering wheel (I now make the sign of the cross first) and go....
    Your Cat drag car... aewsome but need pictures.. I'm old... can't recall........... what waz I saying and to who....
    Pontiac Slim
  7. Captain Chaos
    Captain Chaos
    from Missery
    As stated you do not need it on a 350T .
    BUt options as requested.
    An aftermarket cut to fit cable . or hook it to gas pedal like Olds did from the factory and that would give you a cleaner look anyways . or make an extnsion like I had to once on a last minute deal for a guy who was out of money .
  8. 39ChevyRatRod
    39ChevyRatRod
    Hello, been there done that, here's the only pic I have of the setup, I used a kick down cable from a Chevy truck with an inline 6, I think the application was late 70s. I made a bracket and mounted it to the carb mounting stud. Hope this helps.
  9. Screamin' Metal
    Screamin' Metal
    from Oklahoma
    I believe we met at a car show once if thats your car in the Avitar......I had a blown 389 Pontiac powered 32'.........
  10. junkyardkat
    junkyardkat
    Thanks for the input and the pic 39ChevyRatRod.
  11. No kickdown cable on a four speed standard.....hehehe.
  12. Pontiac Slim
    Pontiac Slim
    hmm.. ya thats me coupe in the avitar.. a blown 389 32 hmm.. maybe..LOL Hell I can remember the weather yesterday (true my son called tonite and asked).. Must be an age thing or too.. (his)
    Waz your 32 a coupe?.. just can't recall but maybe...where you think...
    Pontiac Slim.....
