Tunnel Ram Risers / Spacers
Discussion in 'Off Topic Hot Rods & Customs' started by sixball, Dec 17, 2025.
  1. sixball
    sixball
    from Indiana
    No longer relevant
  2. 19Eddy30
    19Eddy30
    from VA
    @sixball
    More likely this will be moved to off-topic.
    Will move the power band , might need to richen up ,
    I have ran Vic Ram & H -Strip Dominator intake ,
    Not familiar with Weiand characteristics. In line or Side saddle carb mount ? I have made & used T-P top , but if the Weiand I think it is , not able to do .
    On one of the set ups I moved the rear carb
    One inch forward to deal with cowl .
    Data logger showed No change .
  3. swade41
    swade41
    from Buffalo,NY
    No idea but I'd ***ume you'd have to tweak it a bit since you are lengthening the runner. One thing is for sure I'd sandblast them so they'd match the cast intake better.
    Weiand tunnel ram risers https://share.google/fCGYIm4j7F6VXymh1
  4. 19Eddy30
    19Eddy30
    from VA
    I'm ***uming this 4 inch spacers are going to be between the upper and lower of the intake?
    Not the carbs !
