Hot Rods turbo 350 to rock crusher - how much of a PITA?
Discussion in 'The Hokey Ass Message Board' started by Logan O'Brien, Jun 14, 2015.
  1. Logan O'Brien
    Logan O'Brien
    Hey guys - I've never done a trans conversion before so I was wondering if I wanted to swap a turbo 350 to m22, what kind of pain am I looking at?
    Every model A in my area is either a factory resto or someone's project they dropped a granny tranny in.
    Thanks for any help!
  2. squirrel
    You need to buy a clutch, flywheel, bellhousing, transmission, shifter, figure out clutch pedal and linkage, probably get a new driveshaft (splines are different), and probably a few other things I forgot.
    btw without knowing more about the car/engine, it's kind of likely you'll be better off with a M21 instead of a M22....at least it would cost less, and save you the hassle of a different driveshaft. But if you're set on an M22 because of the sound and the mystique, then don't worry about it.
    lothiandon1940 likes this.
  3. DDDenny
    Like a pilot bushing Jim.
    squirrel likes this.
