Hot Rods Turbo 400 Trans.
Discussion in 'The Hokey Ass Message Board' started by krylon32, Mar 15, 2023.
  1. AHotRod
    AHotRod
    I got a TCI Turbo 400 in my Coupe now for 23 years and it's been beat on almost daily and on the drag strip to ... I love it.
    Deuces likes this.
  2. Doublepumper
    Doublepumper
    from OR-WA, USA
    The plates are only 1/8 thick, so not needed. I used one on a 350 Pontiac, and it was easy-peasy.
    Budget36 likes this.
  3. theHIGHLANDER
    theHIGHLANDER
    Since this thread was awakened from a nap I'm gonna chime in again, about OD yes or no. OD is nice. We're all conditioned to OD now from our trucks n daily drivers. WTF did we do until the late 70s when OD became the thing? We ran axles 3.31 and numerically lower. That 2.48 1st gear in a 400 takes the sin away from "highway gears" in a light car. Big sedans ran 2.78s, some even had taller than that. Take away 2000#.
    I did say dinosaurs are kool tho so there's that...:cool:
    BJR, X-cpe, 427 sleeper and 1 other person like this.
  4. BIGEVIL
    BIGEVIL
    While on the subject of TH400, can some members please post how they configured a WOT switch?
    I've looked at some ideas of how they use ones for NOS systems but my twin Holley 600s have electric chokes so the back barrels throttle shaft idea won't work.
  5. nochop
    nochop
    from norcal
    I’m toying with the idea of a momentary switch on the shift lever. Any other ideas? I didn’t really want to muck up my 3 deuce set up. I also don’t want to muck up my shifter either
  6. Doublepumper
    Doublepumper
    from OR-WA, USA
    I made up a home brew switch using a pull/on type motorcycle brake light switch and a cable slider fitting on the carb. With an adjustable stop on the cable I can adjust where I want the switch to activate. I have a spring on the switch that allows for throttle movement after it's been activated.
    nochop likes this.
  7. Elcohaulic
    Elcohaulic
    The stator in the Turbo 400 converter changes that 2.48 to a more performance friendly 5:1..... The Super Hydra-matic came with a 3.97 first gear because it didn't have a torque converter.
    My all time favorite is the 64-66 Buick Oldsmobile switch Pitch converter..
    https://www.pontiacstreetperformance.com/psp/Twisting.html
    Hamtown Al and AHotRod like this.
  8. saltflats
    saltflats
    from Missouri
    You could put a micro switch under your foot feed to actuate it.
    swade41 and nochop like this.
  9. BIGEVIL
    BIGEVIL
    I thought about that, I'm just concerned I might kick it or something since my pedal pivot is at the firewall instead of on the floor.
    I attached a picture of one I like, but my carbs have vacuum secondaries and electric chokes. My throttle shafts for the back barrels are somewhat inaccessible with additional hardware.
  10. jaracer
    jaracer
    I also used a pull type switch connected to the carb throttle lever with a spring. It is a NO switch that I mounted in a small box (the black box in the picture) and then filled the box with epoxy to weather proof it. It is on a pedestal that is located by one intake bolt. It is sturdy and works well. However, the engine is a 401 nailhead and it is in a Model A. So far it accelerates quite well in high gear without needing to use the kick-down feature.
    Deuces, BIGEVIL and Doublepumper like this.
  11. 1971BB427
    1971BB427
    from Oregon
    That's a option to run taller rear gears, but then we lose some performance off the line, and still cruise at fairly high rpm's at freeway speeds. One of the reasons cars began to get higher mileage before needing rebuilds is the low rpm's cars with an OD trans allowed. And no sacrifice in low end performance.
    I still run a non overdrive trans in my Austin g***er, just because it's not a long haul highway cruiser, so my 3.73 rear gears are fine for local 55 mph freeways, and around town. But I went OD on my '39 because I take it on long trips, and with 3.73 gears it still cruises at around 2100 rpm's at 65 mph. Makes it a much more useful car to go on long trips with.
  12. BIGEVIL
    BIGEVIL
    Looks original. Great job there
  13. ClayMart
    ClayMart
    swade41, Hamtown Al and Algoma56 like this.
  14. krylon32
    krylon32
    from Nebraska
    When I built my first car (32 Ford Roadster 1980)with a 400 turbo. I didn't use a kick down switch. I just pulled the shift levee down and hit the gas. Didn't know any better, also did something different, just looped the trans cooler line and drove it all over the US with no problems. I must of been lucky??????
    Hamtown Al likes this.
  15. @ClayMart , I was going to bring up the pedal mount, but you already did, with a link as well. I probably have that switch in my shop somewhere, but I misplace the tools I'm using now, can't imagine trying to find a switch that is "somewhere" here!
  16. Robert Pierce
    Robert Pierce
    T400 in my 56 for 45 years. Super tough. Shifted great. I replaced it with a tkx 5 speed last year.
  17. Budget36
    Budget36
    When my dad put the TH400 in my pickup, he used the pedal ***y from the Vette. It has the kick down switch mounted on it. Doesn’t have a “vintage look” though. I’d bet bet GM didn’t just use it under the pedal as a Vette only thing.
  18. mohr hp
    mohr hp
    from Georgia
    This is where the Switch Pitch 400 is perfect. It's a poor man's overdrive. And no computer! Now to just find one!
  19. BJR
    BJR
    Cadillacs in the 70's used a switch on the carb for the kick down.
  20. ClayMart
    ClayMart
    The pedal mounted switch I mentioned above was used on the more common GM TH400 equipped cars as well as trucks, if I remember correctly. Probably thru the 70s and a bit into the 80s. The same switch was also used on some O.T. Z/28 Camaros to open the air flaps on the cold-air induction hoods. Maybe that's why the part# was still stuck in my giant brain.
    :rolleyes:
  21. Budget36
    Budget36
    I read your post, but didn’t realize you were referring to the pedal switch that could be used, I had thought of it as one ***y (pedal and switch, etc). Good call.
    ClayMart likes this.
  22. iafraser39
    iafraser39
    from Warmland
    In my moddel A RPU I run a 425 nailhead with a switch pitch T400 ******.
    I have the kick down and the switch pitch wired to a 3 way toggle on my
    shift leaver. It works quite well.
    nochop and Hamtown Al like this.
  23. 1971BB427
    1971BB427
    from Oregon
    My OT '69 Suburban uses a switch on the carb linkage also for kickdown.
  24. roddering
    roddering
    from Arizona
    Got one behind my motor in a sedan.
  25. krylon32
    krylon32
    from Nebraska
    How did I get away with not having some form of electric kick down?
