So I would like to hear some Y block gurus weigh in on Putting a reasonable sized turbo 6-8 psi on an otherwise Internally stock 292 from a 62 Truck it has the best factory rods And a forged crank I think it's got bad heads so a turbo Set up would produce great power without sinking 1500 plus In good heads and speed equipment Any thoughts suggestions or concerns would be awesome I do realize all the obvious concepts behind a proper turbo install So let's focus on the engine it's self
here is a link to a Y-block turbo...hope it helps http://www.theturboforums.com/smf/d...d-turbo/?PHPSESSID=dtudf7gpl6j7h64t96dqjin3f6
6-8 PSI = not much to do other than the obvious good operating condition and better than good enough oil pressure to put your turbo gear on. Bigger ring gap and a cam with close to 0º of valve overlap.
