Turn signal brake light help
Discussion in 'The Hokey Ass Message Board' started by ironhill, Aug 11, 2013.
  1. ironhill
    ironhill
    from Simms, MT
    Hey guys, searched and searched but can't come up with anything. Wiring in turn signals with brake lights using a simple 3 way toggle switch, have wired it up with the double relays, turn signals work but no brake lights. When the turn signal is flashing and set on the brake just it turns into a brake light any help would be great! Thanks
  2. You need two 1-pole/double throw (1P2T) relays if only running rear turns. If you have front turns and/or dash indicators, those need to be 2P2T relays.
    Connect your rear turn/brake light for each side to the 'common' on each relay. Connect the brake light power from the brake light switch to the normally closed (NC) contact. The turn power from the flasher goes to the NO contact. Connect your toggle switch (which should be a on/off/on type) so the switch powers up the left or right relay coil.
    If you have front/dash indicators, connect those to the other common on your 2P relay, and connect the turn power to the other NO contact.
  3. ironhill
    ironhill
    from Simms, MT
    Thanks ill give that a try when I get some of those relays, I was trying to wire in the 5 pole ones with no luck
  4. d2_willys
    d2_willys
    from Kansas
    try this diagram:
  5. cherokee_64
    cherokee_64
  6. d2_willys
    d2_willys
    from Kansas
    Here's another possibility. It uses standard 5 pin auto relays, and a dpdt center off switch.
