Technical Turn signal flasher constantly energized
Discussion in 'The Hokey Ass Message Board' started by ShortyLaVen, May 30, 2018.
  1. ShortyLaVen
    ShortyLaVen
    Hey all! I'm scratching my head at an odd electrical issue, and figured maybe getting some extra minds on it would help.
    I'm working on a slightly OT car (later 60s Newport stocker), replacing the signal cam and fixing some other electrical things. To start with, the signals were not flashing at all. I replaced the signal cam (broken cancel tabs) and got it all working, and then when I installed a new flasher it clicks constantly. I've fiddled with the contacts on the cam, tried several different flashers, still just constant clicking.
    I haven't really trouble shot it much, just looking to brainstorm some ideas of what might be the culprit.
  2. F&J
    F&J
    A flasher, the old style mechanical ones, are nothing more than a circuit breaker. If you have no lights flashing outside or on the dash..., then you have a short, or a draw on the output side of the flasher.
    Hnstray likes this.
  3. Reverse the leads on the flasher.... I had this issue once, and that's what it was.
    Truck64 likes this.
  4. Mr48chev
    I'd have to agree with there being a short somewhere. Most likely between the flasher and the switch.
  5. Chappy444
    Chappy444
    Is the blinker fluid reservoir full? A low level will cause all kinds of problems.
    <my apologies, I couldn't help myself>
    Chappy
    CapeCodBob likes this.
  6. tb33anda3rd
    tb33anda3rd
    i can not remember which car i worked on that used a special flasher. i thought it was a late 50's pontiac. what was the part number on the original flasher?
    how did the canceller fix a no flash problem?
