turn signal help
Discussion in 'The Hokey Ass Message Board' started by thommoina33, Oct 31, 2010.
  1. thommoina33
    thommoina33
    Alliance Member
    from australia
    g'day guys, just need a little help.out in the shed today wiring up turn signals on the '31 coupe.it's still banger powered 6 volt positive ground.
    i fitted up one of those chrome vintique switches,all pretty straightforward, soldered connections,all pretty neat for a rough ***** like me. i tested them out and all i have is a solid light (not flashing)coming on.i pulled the flasher unit of my '33,which i know works but same prob.maybe bad earth?but why would the globes glow.
    cheers,thommo.
  2. George T G
    George T G
    You need a draw to make the flasher work. Did you use LED's with a non LED flasher?
    GEORGE!!
  3. PlyPals
    PlyPals
  4. thommoina33
    thommoina33
    Alliance Member
    from australia
    thanks for the input.the lights are the small rodlights,i just checked the globes and they're the 6v 1 cp (vintique globes)standard single fillament.
    i changed over the globes just in case and cleaned all earth contact points.the front lights are mounted through a front hole in the ch***is(car is a hiboy)and the rears are mounted to the body(very rear,underneath).still the same prob.
  5. model.A.keith
    model.A.keith
    Is your flasher unit +ve earth ??
  6. thommoina33
    thommoina33
    Alliance Member
    from australia
    keith,the flasher unit is a 6v vintique,part no; A-13350-6V. 32CP.
    not sure if its neg or pos ground.
  7. model.A.keith
    model.A.keith
    thommoina33
    Needs to be +ve ground..................been there ,,,,,,,and got the T shirt !:D
    Keith
  8. thommoina33
    thommoina33
    Alliance Member
    from australia
    spot on model a keith,problem solved,thankyou all.:)
  9. thommoina33
    thommoina33
    Alliance Member
    from australia
    ok guys,i'll bring this back up,thought i had the problem solved,
    obtained good earth on column where switch mounts and lights worked.
    went and rechecked today and old problem again,just non flashing lights,they illuminate but don't flash. i rechecked all earth points where lights mount,seem all o.k.replaced flasher unit,still no good.
    i don't like to send work out so any ideas, thanks,thommo
