Turn signal wires
Discussion in 'The Hokey Ass Message Board' started by broderchamp, Jul 26, 2013.
  1. broderchamp
    broderchamp
    I got this old steering column from the wrecking yard to use in my Model A. The column came out of a 1954 Ford Pickup. It has six wires to run the turn signals. I figured out that there is one that I fugured would be the power source and two that are the right and lef turn positions. What are the other three wires for? The horn wire runs through the center of the steering shaft.
  2. You should have left front out , left rear out , right front out , right rear out, power from the flasher in, and power from brake light switch in.
  3. Mike51Merc
    Mike51Merc
    1. FL
    2. FR
    3. RL
    4. RR
    5. Brake light switch
    6. Feed from flasher relay
