I'm using an EZ-Wire kit to re-wire my Desoto. I'm to the turn signals right now and need some help. I think I have what wire does what out of the column but I was mocking up a testing fixture with extra sockets and flashers and stuff but no blinky. Does someone have a common wiring diagram for the blinkers? Thanks
I know this may sound dumb, but did you ground your fixtures and wire brush all your connections so they are CLEAN? Also, if the light goes on, but won't blink, your wires are crossed somewhere. Hope that helps. ~Melissa
Did the signals work BEFORE ??? If not---problem is in the column.........do ya have BRAKE lights ?? (brake/turn uses the same filament in the bulb)Brake lights go THRU THE COLUMN and are 'broken" side by side by the switch/flasher combo..........call EZ Wire---good people--they'll help ! Jersey Skip
Thanks for your help. I got them figured out. Let's just say that I wasn't thinking straight. I had a wire labled wrong. Oops.
