1952-59 Ford Turn signals
Discussion in 'Off Topic Hot Rods & Customs' started by 55fordcust, Apr 3, 2017.
  1. 55fordcust
    55fordcust
    from ohio
    so I did a quick search on removing a turn signal switch and came up empty handed. Anyone done one of these on a 1955 custom line?
  2. HOTRODPRIMER
    HOTRODPRIMER
    You have to pull the steering wheel to get to the switch,it attaches with screws. HRP
  3. Paul2748
    Paul2748
    Got a shop manual? It helps
  4. 55fordcust
    55fordcust
    from ohio
    I don't have a manual unfortunately and dealing with a different style wheel
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    On a Grant wheel like yours pop off the horn ****on under that is the horn ring and adapter hub the wheel is held on by 3 bolts remove it and the hub adapter the turn signal is under that. Here is the adapter kit used on your Ford.
  6. 55fordcust
    55fordcust
    from ohio
    Thank you! I've gotten a bunch of wiring done and now for the inner guts or wiring. The group is most knowledgeable hands down
  7. 55fordcust
    55fordcust
    from ohio
    Going on a feeling that the shaft has to be pulled out to get this, correct?
  8. danman55
    danman55
    The shaft will not need to come off, but that aftermarket adapter will before you can remove the turn signal switch. Do you have a puller that will fit that Y shape? it should remove pretty easily. After that is just a matter of a couple of one small screw and bolt to lift the whole switch out of the cup. (as I recall anyway)
  9. 55fordcust
    55fordcust
    from ohio
    So the "y looking part" just needs to be pulled off the shaft? Just a typical puller for a crank pulley or something should do?
  10. Tomdob
    Tomdob
    A pulley puller would be overkill. You need a steering wheel puller. Any good parts store will have 'em.
    JeffB2 likes this.
  11. JeffB2
    JeffB2
    from Phoenix,AZ
  12. 55fordcust
    55fordcust
    from ohio
    Anyone know where the wires go for this? Previous owner never had it hooked up.
  13. Jimmy2car
    Jimmy2car
    from No. Cal
    Are those the turn signal wires from the column?
  14. 55fordcust
    55fordcust
    from ohio
  15. JeffB2
    JeffB2
    from Phoenix,AZ
  16. 57Custom300
    57Custom300
    from Arizona
  17. JeffB2
    JeffB2
    from Phoenix,AZ
    These diagrams usually print out at 8 X 10 I went to a Fed-Ex copy shop and had it blown up to an 11" X 14" and laminated cost about $6 made it a lot easier to read and grease proof.
