Technical Turn signals
Discussion in 'The Hokey Ass Message Board' started by Jgress77, Apr 16, 2026.
  1. Jgress77
    Jgress77
    1953 ford customline. Right front turn signal wont work. I have 12 volts to the socket and the bulb is good. But the socket is rusty and hard to get the bulb in and out. How can I fix this?
  2. 19Eddy30
    19Eddy30
    from VA
    Yes wire brush in Dremel size ,
    Dremel or drill
    Ground just as important as a Hot
    osage orange, Paul and Just Gary like this.
  3. jaracer
    jaracer
    Are you using an 1157 bulb? If you are, do the parking light work?
  4. Jgress77
    Jgress77
    I am and I dont think so. If you are referring to the first click on the light switch where the headlights dont come on then no they dont...
  5. Jgress77
    Jgress77
    Okay... I cant even hardly get the bulb to go in and turn... also arnt the prongs supposed to be spring? Theyre solid
  6. BJR
    BJR
    If you have one of those hand held sand blasters, give the inside of the socket a blast. It will solve a lot of problems.
    osage orange likes this.
  7. 19Eddy30
    19Eddy30
    from VA
    There is usually at least all I have seen
    A spring for twist in bulbs below insulator.
    Some newer bub's are size wrong ,
    If to tight , m***age size with a brush on drill or take a bolt / rod cut a slot & use emery cloth/ sandpaper like making flap wheel
    Single Element bulbs pins are straight across on dual filament are staggered
  8. Tim
    Tim
    from KCMO
    Just cut it off and wire a new socket. Seems faster than trying to get the old one clean enough to function?
    osage orange, Wanderlust and flat Ike like this.
  9. 53 Fords are wired where the parking lights come on with the first position of the light switch and go out when the second position headlights come on. If both sides are not on in the first position and you have voltage at the bulb pin, it is a ground problem.
  10. Jgress77
    Jgress77
    Im converted to 12v negative ground
  11. Jgress77
    Jgress77
    Where do I get this socket
  12. Tim
    Tim
    from KCMO
    If you wanted a factory replacement I would look at Mac’s website - though they ship faster via buying through their eBay account
    if you don’t mind if it’s factory exact a common socket pigtail from any Napa would work. Standard Dorman help stuff.
  13. Tim
    Tim
    from KCMO
  14. Jgress77
    Jgress77
    I may have to do this. I can push the bulb to one side of the socket and itll work im gonna try to get some emry cloth after it tomorrow and see if I can get it working now I know its not getting connection like other suggested
    Tim likes this.
  15. jaracer
    jaracer
    Either side or just the one?
  16. spudshaft
    spudshaft
    Is the center of the socket intended to move in and out? If so, spray some lube in there and work it back and forth. I’ve had luck that way.
  17. gene-koning
    gene-koning
    I have seen replacement bulb sockets with the pig tails like the one shown that also have a tab you can connect a ground wire to. When ever I have replaced a bulb socket, I use the ones with the tab, and I will run a ground wire from it to someplace I can get a good ground.
    The sockets with the little crimp edges only grounds through the crimped edge, and then still ground through the screws that hold the light housing to the fender. Poor grounds are the reason many lights on older stuff don't work anymore.
  18. Mr48chev
    If you were to pull the inards out of the socket they would look somewhat similar to this Pico pigtail. They used to be available through NAPA but it has been years since I bought one. They have to have the right ***s on the sides of the top washer to orient them right in the socket.
    Anyhow when you put the bulb you are puishing on the contacts and then pushing against the spring. You might get by with spraying the socket with a good rust buster and hoping that the washer will slide and the spring still has some tension in it. Screenshot (3168).png
    Driver50x likes this.
  19. Jgress77
    Jgress77
    Its got 2 little prongs that I think are supposed to move
  20. winduptoy
    winduptoy
    I use a 1/2" copper tube fitting brush to clean the socket internally....don't know what I would do without it.
    a 3/4" works wonders for battery cable terminals...batter in outcome than the cheezy battery brushes that the auto stores sell...
    also....a 12V bulb in a 6V socket may have the bulb oriented so the terminals on the bulb may not be aligning with the 6V socket ..... instead of changing the socket I've addressed this by adding some solder to the bulb terminals in an offset direction...and do a couple of spares this way to keep in the glovebox if this is the case...
    good luck
  21. Jgress77
    Jgress77
    All the other bulbs and sockets work... its just this one and if I push in or to the side or something itll work but wiggles around and loses connection
  22. I also converted my 53 to 12V negative ground as I am running a SBF motor (right now). Replace the socket.
  23. What you'll find if you dis***emble the socket is the spring or springs that keep tension on the contacts are rusted/broken. Clean everything up and replace the springs.
  24. 325w
    325w
    Cut it and get the replacement socket.
  25. Jgress77
    Jgress77
    I actually got them free but the socket itself is loose enough the bulb just wiggles lose... its for a different guy. I actually pushed a spade crisp connector in between the bulb and socket and its been working good. He said we wont worry about it til it stops working . If that happens i told him to order a socket and id come replace it for him
  26. 19Eddy30
    19Eddy30
    from VA
    A Dab of solder or shim , few strains of wire to tighten up,
    & I was one many times when Young rap foil on fuse, pennies in screw
    in fuse :confused:
  27. Squeeze the socket together a bit where the pins locate until the lamp just fits. The pins are where the ground connections actually are, get those areas clean and tight and that should permanently fix it.
  28. RICH B
    RICH B
    You mentioned going to use emery cloth to clean the socket. An easy way to clean the inside is to cut the head off a long 1/4" bolt, sawing a lengthwise slot, put it in a drill with a strip of emery cloth in the slot, and use your new "sandpaper on stick" to clean the inside of the socket.
    Another question.
    Is the socket made for the offset pins of an 1157 bulb?
    Many 6 volt dual filament bulbs had straight across pins with "top" printed on the bulb.
    Used to be a 12 volt bulb made with straight pins to fit the old 6 volt style sockets.
