Turning drums
Discussion in 'The Hokey Ass Message Board' started by Crankhole, Mar 2, 2009.
  1. Crankhole
    Crankhole
    Is it necessary to have new brake drums turned before installation?
  2. 55 dude
    55 dude
    no. just make sure its cleaned with degreaser.
  3. Crankhole
    Crankhole
  4. 61bone
    61bone
    They don't necessarily need turned, but should be checked for true and turned as necessary to correct any defects.
  5. skidsteer
    skidsteer
    What 61bone said. I had a brand new rotor almost shake my teeth out the first time I stepped on the pedal. They're not always true when they come off the boat.
  6. Zeke T.
    Zeke T.
    Yes, 61bone is right. I've had a lot of experience with cheapo house brand drums and rotors and there's always the chance that they are not true. A little pre-check will save a headache later.
  7. roundvalley
    roundvalley
    We used to arc/true the shoes to the drum. Is that still recommended?
  8. BigBlockMopar
    BigBlockMopar
    Roundvalley,
    I would say 'no' if the drums and shoes are new.
    But if you put new brakeshoes in used drums if would be advisable to do so yes.
    And again what's been said earlier, it never hurts to check everything out, even with all new parts.
  9. 325w
    325w
    Do it. You want be sorry.
  10. Wheelie
    Wheelie
    from Dallas
    Check it for sure, I can't count how many new "Chinese" parts I install or mock up that don't quite fit or in this case, be true and round.
  11. HighSpeed LowDrag
    HighSpeed LowDrag
    from Houston
    Personally (20+ years), I cant remember installing a new drum on a customers car that wasn't round out of the box. Rotors - installed quite a few that were aldready warped straight out of the box.
    If it were my own car I wouldn't turn them but then again, I have access to a brake lathe so if I make the wrong choice, it costs me only my time.
  12. Retro Jim
    Retro Jim
    When I was a mechanic for Ford & Chevy I did mostly emgine work and many brake jobs . I NEVER put a new drum or rotor on without turning them . In almost all the cases they were out of round . Most were very close but not too bad but some were awful ! Why take the chance by doing all that work and it being out of round . Good brakes is the most important thing on the car you depend on the most ! Just my 2 cents worth !
  13. RichardW
    RichardW
    Also check that they are "centered" I have purchased ofshore drums that were core shifted.
  14. tommy
    tommy
    When I started helping my buddy at his brake shop almost 30 years ago now, I used to be the designated drum/disc turner. It was a cl***ic old fashioned quality shop that always turned new drums. 5 bay high volume shop. I never found a new drum that didn't need a slight cut. He insisted that new ones got trued. Some were worse than others. Some you would probably never notice but I never saw a perfect new one. Can you get away with out truing them? Probably but if you do enough you will be bringing one back in to true both rear drums to make sure that you got the culprit.
  15. New Old Fart
    New Old Fart
    After 25 years in auto parts I can say that I never sold a true drum or rotor.
    Raybestos and Wagner where close , but when the China **** started showing up it was not uncommon to take .030 out/off to make it round or true.
  16. I turned every one I ever put on and never once was there a perfect one. When you do it for a living and when you have to do it again free if it isnt right you very quickly learn what to avoid. Green castings are a big problem expecially brake drums. if it is your own and you dont mind doing it twice you could take a chance but customers have a very dim view of jobs the require two trips
    Don
    Re shoe arc. it gives a firm brake pedal right away and makes for a very nice job but very few shops have them anympre
  17. It's hard to find a place that can do it any more or even knows what you're talking about.:(.
  18. BJR
    BJR
    That's because all the old timers who arched brake shoes died of lung cancer from the asbestos in the grindings they were breathing. I think OSHA stopped that.
  19. Good point. :(
  20. oilslinger53
    oilslinger53
    from covina CA
    I have them turned, and have the shoes matched to the curvature. You dont have to, but it seems to stop a little better this way. I think Ed's auto parts in covina still does it.
  21. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Put those Chinese drums in that American lathe and do it right.
