1952-59 Ford turning signal
Discussion in 'Off Topic Hot Rods & Customs' started by BeerMoney, Jul 24, 2020.
  1. BeerMoney
    BeerMoney
    i just replaced my turn siganl switch on my 55 customline and it wont stay on while im turning
    is there something im doing wrong it is brand new
    thanks Bobby Parrish
    appreciate all the info
  2. TomDobbs
    TomDobbs
    Check the cancel collar position. It's a collar under the steering wheel with a notch in it that engages the cancel pawl on the switch. It looks like it's made onto the wheel but it's not.
  3. bobss396
    bobss396
    Mine is out of adjustment, I'm just too lazy to pop the steering wheel off. Great on left turns, shallow right turns I have to hold the lever up. This is the plastic canceling thing on my car. Also look on the bottom of the steering wheel for a canceling plate made of plastic. They get old and brittle.
  4. 54vicky
    54vicky
    I doubt it is the cancel ring on steering wheel.there are (or should be)2 springs one is wound around the stub that the stalk screws too the other is on the under side of switch below the oblong box that the wires come from.the wound one helps the cancel action the other holds it in left or right position
  5. BeerMoney
    BeerMoney
    thanks
    i only see one spring its one the little stube
    do you have a picture of where the other spring goes
  6. 54vicky
    54vicky
    PB270014.JPG hopefully these pics help.one other thing I forgot to mention if that odd looking piece that spring is attached to is missing then it will not work as it is needed.again hope this helps it is the dark piece sorry about flash
  7. 54vicky
    54vicky
