tv cable turbo 350
Discussion in 'The Hokey Ass Message Board' started by rer_239, Aug 28, 2013.
  1. rer_239
    rer_239
    My ****** leaks where this cable enters the case. Does this cable just pull out so i can replace the 2 o rings?
    Thanks
  2. TudorJeff
    TudorJeff
    Yes, it has a little offset hook on the end so you can disconnect it from the trans internals, then replace the sleeve and o-ring.
  3. comes right out , usually held in with one small screw. then pull the outer up to expose the inner cable were it hooks to a small bent wire
  4. saltflats
    saltflats
    from Missouri
    The easy way is to unhook it from carb unbolt it from ****** then pull it up and use some needle nose vice grips to hold the the wire that goes in the ****** up so you can unhook the the cable from the wire.
  5. TudorJeff
    TudorJeff
    good idea!
  6. Clean the hole and cable end, but don't put any snot on the seal, it will leak again..
  7. rer_239
    rer_239
    thanks guys, i still can't believe this place. ask a question and 15 minutes later 4-5 guys give you a detailed answer. unbelievable.
    thanks
  8. hoop98
    hoop98
    from Texas
    PS; it's a detent cable on a 350, not a TV Cable
  9. shop teacher
    shop teacher
    Also 2 types of seals : early had O ring, newer had a boot type.
  10. rer_239
    rer_239
    oops detent cable. my had the two o rings. anyway replaced them and its no longer leaking.
    thankjs
  11. HOTRODPRIMER
    HOTRODPRIMER
    You think you have a leak,,I got in such a hurry when I was building my 1939 convertible I forgot to hook up the cable.. imagine driving down the road with a hole in the transmission.
    I didn't take log to figure out my problem..transmission fluid everywhere. HRP
