two gauges on one sensor, can this be done?
Discussion in 'The Hokey Ass Message Board' started by big creep, Mar 30, 2011.
  1. big creep
    big creep
    hey gal and guys, is this a stupid question? i want to run my stock 49 ford gauges and a modern auto meter gauge, can this be done on the same sensor?
    i know if i add a switch i can go to one or the other, but can they both work at the same time? im going to have the modern ones hidden, i want to do this for the water temp, oil. i think i know the answer but it never hurts to ask. thanks in advance.
  2. Arent the stock ones mechanical? Not sure how youd splice into the lines to run two gauges.
  3. big creep
    big creep
    at the same time?
  4. wont work they have diffrent resistance values
  5. treb11
    treb11
  6. big creep
    big creep
  7. marks914
    marks914
    Alliance Vendor
    Yes
    but you need a dual station sender, we use them in marine applications quite a bit. One gauge in the engine room and one on the bridge
    Mark
  8. 325w
    325w
    No. Your stock gauges have a different sender.
  9. blown49
    blown49
  10. big creep
    big creep
    well how about just getting the original oil and water temp gauge redone to pick up on a modern sending unit? that would work right. its just to have a number, i feel better knowing what temp its running, then having just a simple hot cold gauge.
  11. KrisKustomPaint
    KrisKustomPaint
    why not just mark the gauge for degrees?
  12. big creep
    big creep
    cause im not sure how accurate the original gauge reads.
  13. KrisKustomPaint
    KrisKustomPaint
    well as far as the coolant temp goes you could always tap it for a second sender for the aftermarket gauge.
