two lane blacktop 55 window ??????
Discussion in 'The Hokey Ass Message Board' started by Motorbreath, Mar 11, 2008.
  1. Motorbreath
    Motorbreath
    For those who have seen the movie, were the sliding windows something comonly done back in that timeframe on drag cars? I've never seen another car with windows done like that.
    For those who haven't seen the movie, go watch it.
  2. hairypalms
    hairypalms
    The Mechanic: You'd have yourself a real street-sweeper here if you put a little work into it.
    G.T.O.: I go fast enough.
    The Driver: You can never go fast enough.
  3. speedtool
    speedtool
    Can't say about drag stuff, but on European sportscars I've seen it done a lot.
  4. Motorbreath
    Motorbreath
    speedtool, regular street driven sportscars or dedicated racers? Seems like it would leak like a bastard.... and be rather noisy too for a sportscar.
  5. TRuss
    TRuss
    Both. Some really barebones street going sports cars will have windows like that. I believe even the Ferrari F-40 did. Some earlier traditional open top sportcars actually have side curtains. Kind of like a Jeep Wrangler with zip up plastic windows. In those applications it doesn't matter about leaks and noises. The owners find it charming.
  6. Motorbreath
    Motorbreath
    Did the sliding ones on the Ferrari seal at all? Im guessing when you have a Ferrari, let alone one that is "built" enough that the windows are "stripped down" for weight savings, it probably doesnt see much wet weather driving...:rolleyes:
  7. It was all for weight saving....remember the scene where 'the mechanic' is bolting on windshield wipers!
  8. Motorbreath
    Motorbreath
    I know it was for weight savings, just wondering if this was commonly done? or if this is just a very extreme weight reduction?
  9. duke182
    duke182
    i'm not sure it was common but ford actually built several fairlanes equipped with lexan side windows in the 60s.
    they went up and down but you had to pull them up by hand and fasten a strap with a snap to the top of the door frame.
    i think it was for a special race only edition that was sold to specifically selected drivers.
    i think they called the thunderbolts.
  10. Motorbreath
    Motorbreath
    I think its cause its late, but for some reason I really want to know more about these "sliding" windows. Im guessing that it was done here and there, but wasn't a huge thing.
  11. twofosho
    twofosho
    Sliding plexi side curtains in an aluminum frame on a 60 bugeyed Sprite, nothing new here.
  12. wvenfield
    wvenfield
    Many had none. They did drive this from race to race so it was the next best thing to none.
  13. Motorbreath
    Motorbreath
    twofosho, got a pic? I'm really way too interested in this, even though a minute or two ago about doing this on my truck if I can't get some decent window regulator hardware for it without breaking the bank.
  14. metalshapes
    metalshapes
    Not a Drag Car, but my old Racer has a sliding Window...
  15. Mr48chev
    On most race cars with plexiglas windows the glass didn't move. The only American car I ever saw the sliding windows on up and through the movie was that 55. On a gas class car you might save quite a bit getting rid of the glass side windows and regulators an hardware and putting in thin plexiglas. The classes were based on pounds per cubic inch with a bit of range in there so if you could drop 40 or 50 lbs and still make the minimum weight for the class you usually did it.
  16. Motorbreath
    Motorbreath
    I guess what I was wondering is this (the sliding windows method of weight reduction) a one car only thing, or is is something alot of people did?
  17. My Fiat Simca (Topolino) has side sliders.
  18. 567trishop
    567trishop
    from Australia
    I made sliding plastic widows on my 55 chev, because the door are glass it also made it easy to make as well as saving weight
  19. The TLB car had a lot of glass body parts, front end/doors/trunk, making it logical to do the door windows that way, but to answer your question; it was not common. Most guys used a glass front end but used steel doors, then to save weight would delete the wing vents and put plexi with two straps with snaps so they could lower it, It gets mighty hot in the staging lanes in Texas! As for the movie car, only the money up racers trying to hit a certain weight break went that far. As a side note; that car was not built for a certain class, as it was built specifically for that movie. The guy that did the build later said that he would never have gone to those extremes had he known what they were going to do with it!!!!!!!!!!
  20. texoutsider
    texoutsider
    from Frisco, Tx
    Not to ruffle feathers, but hell yes a lot of cars had sliders installed...most of my 55 gassers had em........gets hot in Georgia also. It was a cheap and easy way in most post cars to save weight and get a little fresh air. Many did NOT do it...a few of us went the extra mile.
    m.
  21. Rick Sis
    Rick Sis
    from Tulsa OK
    I can remember seeing this on other cars, but it was pretty unusual. If you are considering doing this on a street driven car, it seems like it would be a real PITA to me. But, I'm one that thinks shaved door handles and poppers are a PITA too.
  22. deuce295
    deuce295
    Had a 64 Austin Mini Cooper while in the service in England. It had sliders. They didn't leak in the rain but they did mount the distributor right behind the grille in the front and the radiator was mounted off to the side of the engine so during the rain all the water sprayed on the ignition. Not the best idea to be sure.
  23. Rudebaker
    Rudebaker
    from Illinois
    I remember seeing a few bracket cars back in the 70's with sliding windows in the driver's door and most of those were recycled 60's drag cars. Not real common but it wasn't unique to the TLB '55 either.
  24. Dodge did it on the 1968 Hemi Dart
    Lars
  25. 6t5frlane
    6t5frlane
    from New York
    The 68 Hemi Darts had them also
  26. R Pope
    R Pope
    Wasn't that the same '55 as in Graffiti?
    My '62 IHC Scout had sliding door windows, a real pain.
  27. TRuss
    TRuss
    Did I see an Abarth? What is that Metlashapes?
  28. Catdaddyo
    Catdaddyo
    Yes, it was the same car that was in Graffiti. wan't it that they couldn't raise the hood because it had a Big block in it ? what year did the Big block come out ?
    Kevin
  29. metalshapes
    metalshapes
    Yep, a Fiat Abarth 1000TC.
    Not a Drag Car, but it Drag Raced once...:D
  30. Motorbreath
    Motorbreath
    Well I do believe I have my answer. Thanks guys.
