Type of welder used when doing frame/chassis work
Discussion in 'The Hokey Ass Message Board' started by J Man, Feb 23, 2009.
  1. J Man
    J Man
    from Angola, IN
    What kind of welder does everyone use when building their frame/ch***is? (mig, tig stick, other) If you want to add this in, what brand/model of welder do you use as well? (Lincoln, Hobart, Miller, other)
  2. blackout
    blackout
    Low buck used Lincoln 225 for anything thicker than 3/8ths. Hobart Handler for the thin stuff.
  3. kustomrodder53
    kustomrodder53
    I did mine with a Hobart Handler as well, and it was more than enough. Great welder for the money too.
  4. brady1929
    brady1929
    mig welder - miller 175
  5. MIG 220 or TIG 220. No problem using a 110, but perform a fillet fracture destructive test right there with the machine, on the same material thickness as the frame, before using it. If you can set the 110 machine to p*** the test, then your Gold, if not, then get a 220. Carl Hagan
  6. 35Chevy.com
    35Chevy.com
    from New Jersey
    fillet fracture destructive test???
    Please explain to those of us who are unedgimicated
    Thanks, Gary
  7. moon man
    moon man
    Lincon welder 110/ stick welder.....
  8. You cant go wrong with a 220 stick welder for ch***is work sorry im old school :D
  9. May Pop
    May Pop
    30 year old Craftsman 225 amp buzz box,210 Miller MIG setup and Smith welding and cutting oxy/act torchs.
  10. 19Fordy
    19Fordy
  11. Aaron51chevy
    Aaron51chevy
    Here is what I found
    "Fillet weld fracture testing is performed in accordance with various welding specifications. The purpose of this test is to check the weld for soundness (complete fusion, and no major weld anomalies.) The sample is folded over the weld side of the fillet until the sample folds flat upon itself or failure occurs. The fracture is inspected for complete joint fusion and/or weld anomalies."
    So weld to pieces together and bend them in half, and if the weld holds your good.
    I am going to use my Licnolin 135 to tack everything together then borrow a bigger unit (or buy) to finish weld.
  12. r.s.s.
    r.s.s.
    from Alberta
    just got me a new miller 180. can't wait to fire it up on the 37 frame build.
  13. zzford
    zzford
    I've always had good luck with construction adhesive.
  14. thunderbirdesq
    thunderbirdesq
    Lincoln 175 220v mig machine. I have also used a 220 buzzbox before I got the mig.
  15. sjrodder
    sjrodder
    from vermont
    Lincoln persicion 275 for tig and stick , Lincoln 200 for mig. They work well and I like the color red.
  16. SlamIam
    SlamIam
    Millermatic 220v MIG with 0.030 wire for ch***is work and 0.023 for sheet metal, but I lust for the new Miller Diversion TIG for doing sheet metal and aluminum.
  17. Lincoln Migpak 100 for thinner stuff, and a Lincoln PowerMig 200 for the rest.
  18. ma70tt
    ma70tt
    lincoln mig 175 110-quick/small stuff
    lincoln tig 175 220-nicer big stuff
    miller mig 220-quick big stuff
    miller tig dynasty 200-best machine i have!
  19. ct
    ct
    from minnesota
    I used a 220 MIG for the ch***is. For the bodywork I'm currently using a 110 MIG. The 220 will work for bodywork, but I have the 110 so I use it.
  20. EnglishBob
    EnglishBob
    do you use duct tape while the adhesive dries?
  21. Vorhese
    Vorhese
    Is it an ok idea to run a 220V welder off an extension cord off a dryer 220 outlet?
  22. MedicCustoms
    MedicCustoms
    Lincoln 220 buzz box lincoln 110 mig and can us a miller mig 220 if needed and grate stuff for the hole HAHAHAHAHA
  23. 3Mike6
    3Mike6
    My main welder is my Millermatic 35, it's an older unit, probably about like a newer 180 (220v), but is a very forgiving machine. It's fine on sheetmetal with .030 wire, and just as fine turned up to weld 3/16th with the same .030 wire.
    It's not as user-friendly as the newer units, but has a fantastic arc control, I haven't fired up my Miller Vintage in 4 or 5 years, because the 35 just keeps calling me back:)
  24. 3Mike6
    3Mike6
    Depends on how long the cord is, and how long the original run of wire is in your house. you can find the "voltage drop per foot" for 10ga wire 9***ume you have 10ga in your dryer circuit) with a quick google search, then compare to your machines operating voltage range.
    I/e if the machine specs are to run at 200v+, and say you drop 1v per foot (just an example) and you have 210 volts at your current plug, then you can only reliably run a 10 foot extension cord-making sure it's at least the same gauge.
    A lot of people get in trouble when they try to convert thier 14-16ga 110 extension cords, for 220 use...sure, you have three wires there, but the smaller ga wire has more resistance per foot, so heat builds in the extension due to more amperage draw in the extension, things melt, catch fire, etc...long before the breaker trips, because the breaker is there to protect the wire that it's connected to...not anything further down the line..like smaller wire, appliances, etc.
  25. skidsteer
    skidsteer
    If you're gonna use a 220 wire welder, take a cl*** at your local vo-tech or community college. You can do it, but you gotta know how, takes several p***es. Myself, I just like the sparks and noise of an old buzz box, it gives be a good feeling.
  26. Ha Ha, the funny thing is there are a few who are thinking........"Yea, Me too"
  27. 50dodge4x4
    50dodge4x4
    Everytime one of these posts come up, I begin to wonder if I'm missing something.
    Someone posted they use a Lincoln 225 on thicker then 3/8 inch, and a Hobart Handeler 110 on anything lighter. Really, 3/8"? You welding snow plow frames, cause those are the only 3/8" thick frames I've ever seen? And, isn't 5/16" really pushing a 110 welder?
    Then another guy posted that if you use a 220 wire welder you need to take a cl*** because you need to make several p***es to get a good weld???? I think you 2 guys should get together....
    Ah, what do I know, I use my Miller 251 with .035 wire for nearly everything, 20 guage through 1/2", except aluminum. For the aluminum I use my Miller 210 (a 220 volt machine) because it has the spool gun attachment. Pushing the .035 aluminum wire through the 12' whip on the 251 machine is a pita. The only thing I use my old buzz box lincoln for any more is when I weld cast iron, other wise it sits under the bench in the back room. Its all Ok though, here at my little welding shop, 90% of the stuff I do is fix **** welds other people do. Gene
  28. Rick Sis
    Rick Sis
    from Tulsa OK
    That all sounds logical and straight forward, but I'm wondering how a guy that is working with 3/16" or better in his home garage can take his sample and make a cold book fold without some seriously heavy tooling?
  29. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    I have an Airco 460 amp TIG outfit that I use for everything, thin, thick, aluminum, mag, copper. Go to the "The Wade model A coupe" build, look at his welds and then tell me that you can do better with anything else except a TIG.
    Rex
  30. straightaxlenova
    straightaxlenova
    Miller Synchrowave 351 for me.
