Hot Rods Typical roadster windshield frame wall thickness
Discussion in 'The Hokey Ass Message Board' started by fatassbuick, Feb 11, 2025.
  1. fatassbuick
    fatassbuick
    from Kentucky
    Can anyone tell me the tubing wall thickness of typical late teens to mid 20s roadster windshield frames, or know of a source for the channeled tubing the hot rod vendors use? I'm building a 1917 Dodge Bros cut down phaeton to roadster. I know it's out there somewhere, I just can't seem to find it. Thanks.
    dana barlow likes this.
  2. dana barlow
    dana barlow
    from Miami Fla.
    The hard way,is make it your self ;):D:cool:
    ;; 1/2" EMT [ sand off the no-rust topping] ,cut 5/16 to 3/8" slot;; Can be done by, make jig to hold it,and run a diskgringder blade through one side< for gl*** with lots black RTV silicone filling the tube so gl*** is held well{ clean up smooth/add RTV as needed.
    Or,find some small box tube [ 5/16 or 3/8 box,cut off one side= slot,weld into 1/2 EMT done as above/ then same with RTV; but less RTV to hold gl*** { remember to use 2 layer safety gl*** }.
    That is fairly close tom what I had to do,too fix a rusted out frame. I'll add a photo,when I find it.
    Ok; pic,,This was before welding a lot more spot welds,and then cleaning up welds. { by the way,Box tube side cut off with band saw.
    rusty valley likes this.
  3. Try these guys. I just checked the listings, and it didn't show your vehicle but, They have extrusions and build windshields that are not on the market. You'll be surprised at what all they still do.
    [​IMG][​IMG]
    RodStRace and dana barlow like this.
  4. RodStRace
    RodStRace
    Pist-n-Broke and dana barlow like this.
  5. fatassbuick
    fatassbuick
    from Kentucky
    Alright, thanks guys! Dana Barlow,puhleease don't overestimate my skills!
  6. No problem Rod, Click on the link then go to Resources and then to Windshield Channel Cross sections. There are shapes of all the frame profiles they can roll form. It's way kool. Hard to believe anyone is still doing this. I had them build me a new frame for my Rockne Coupe. I had been hunting for 30 years and once I found them, they just made me a new one. You can't beat that.
    dana barlow and RodStRace like this.
  7. Dana; That looks Painful, Time consuming, Difficult, A major Time Loss And a Ton of finish work. There profile 1378 or 3 would have done the job for you in far less time and the material is Chrome Shop Ready.
    3B
  8. RodStRace
    RodStRace
    I'll use this picture to illustrate the difference between DIY and pro.
    Yes, this was a very low end DIY, and the pro is chromed.
  9. 2OLD2FAST
    2OLD2FAST
    from illinois
    7/8" of 6061 t6 aluminum round bar stock , method of choice to cut a 3/8" slot , miter the corners & machine screw together , used thin bicycle tube for bedding , been together for 25 years without problems .
    I used my table saw with a jig to cut the channel , 9 p***es to get 3/8 by 3/8 , power miter saw to cut corners with a jig .
    As R to R says CCR now sells an extrusion ( about a year after I posted what I'd done on the T bucket forum ,I'm sure it was a coincidence) wink wink
    Use blue loc***e on SS fasteners in aluminum , I've found it prevents corrosion
  10. RodStRace
    RodStRace
    Yes, whenever you are screwing one metal into another and you want to take them apart again, it's a good idea to consider various coatings. I got out of car service work years ago, but noticed GM especially was coating a lot of fasteners. Bikes have used this for decades due to vibration more than electrolysis, but our stuff tends toward lots of NVH too. I'd say this is one modern process that is wise to incorporate into our trad builds.
  11. dana barlow
    dana barlow
    from Miami Fla.
    Yup, Over the years,I've used the hard way a lot,; Time* n welding stuff* I had,a long with lot of s**** metal * to make things :D,but often low on the $ :(. I feel good about making stuff vs buy it.:cool:;)
    RodStRace likes this.
