U-Bolts For Explorer Rear
Discussion in 'The Hokey Ass Message Board' started by TimJohnson, Jun 23, 2011.
  1. TimJohnson
    TimJohnson
    I'm working on putting an Explorer rear end in my 48 Ford F-1. The rear spring kit that I bought for it has 3" U-bolts but the Explorer rear has a 3.25" housing. Has anyone had any luck man handling the 3" bolts to work? Or should I just go ahead and order 3.25" U-bolts and widen the spring plates a little bit?
    Thanks, Tim
  2. 50dodge4x4
    50dodge4x4
    Spend the money and get the right U bolts and spring plates. Spreading 3" U bolts to fit around a 3 1/4" housing would not be an easy job, and then the spring plates won't work anyway. Gene
  3. Deuce Roadster
    Deuce Roadster
    You did not get the U bolts when you got the rear end ??? :eek:
    The local U-PULL IT should be full of Explorers ( they are around here :) )
    I threw a set of Explorer U bolts away about 2 weeks ago ... :eek:
    When I get a rear end ... I ALWAYS try to get everything including the driveshaft. Most of the 2000/2001 Explorers have a aluminum driveshaft.
  4. shinysideup
    shinysideup
    from ruskin, fl
    Your local 4x4 shop will make you some cheap. Thats what I did.
  5. FoMoCoPower
    FoMoCoPower
    Only idiots re-use old u-bolts. They are basically the same as torque-to-yield head bolts. When you tighten them,they stretch. Using old ones again is a no-no,they can`t be reliably trusted.
    New U-bolts are cheap. I had the ones for my Explorer 8.8 made for about $10.00 total at a spring shop.
  6. 23dragster
    23dragster
    from U.S.
    I'd get 3.25" U-bolts to do it properly. You can do it with 3", but it'll look a bit funny if you don't spend the time to get them right.
  7. Deuce Roadster
    Deuce Roadster
    I must be a old, old idiot then. Been doing it that way for 40 years. Had a few 10 second drag cars and never had a issue ... :D :D
  8. Mr48chev
    Same here, I maybe bought one new set of U bolts for one of my rigs in the past 40 years. And that was because I worked in a parts house where I got everything for my own rigs at warehouse cost.
    But back to the question. Yes get the correct size U bolts and the local 4x4 shop is probably the first place to check but not all of them "make U bolts" the local one would run down the street to White Front Shop (a spring and suspension shop that has been around since Model T days) and have a set made and then double the price.
  9. Deuce Roadster
    Deuce Roadster
    I also believe that the 10 year old original FORD bolts are most likely a better qaulity than the new stuff that most likely came from China. :eek:
  10. 48FordFanatic
    48FordFanatic
    from Maine
    Just find a spring shop in your area and have them made. I had some made here in Waterville,Maine for an 8-inch Ford rear, $5.00 each for just about any length.
  11. Rickybop
    Rickybop
    Use the right size.
    Better not to use old U-bolts. Could get away with it for years, but still.
    U-bolts from China? lol. They're just bent and threaded steel rod...made right here.
    No need to call people idiots, though.
  12. Might as well sign me up as an idiot also!:mad:
    I have never bought new ones and I have been building old cars for a long,long time! HRP
  13. redhumphries
    redhumphries
    bought a set the other day at my local napa for an explorer rear we put in the 47 dodge truck. They had a book with different sizes and all measurments. Yep I dumb too been using the originals for all my life never had one fail. Good luck with your project RED
