U-bolts
Discussion in 'The Hokey Ass Message Board' started by Voodoo Jim, Jul 27, 2004.
  1. Im needing U-bolts for the rear of a model A. Stock. I have looked high and low, with no luck. Hook a brother up! Please.
  2. yorgatron
    yorgatron
    i dunno,but here's a BTTT for the morning crowd.
  3. willowbilly3
    willowbilly3
    from Sturgis
    Try Britton's Antique Auto parts. 1 800 255 1929. They have new ones for $7.85 each
    Obsolete Ford parts, inc. 1 405 631 3933. They have them for $6.95 each. Nuts cost extra at $4.50 a set.
    Also you could try Sullivan's Garage but I only have them in my bookmark so you will have to Google to find them.
  4. Deyomatic
    Deyomatic
    from CT
    Is Obsolete the place everyone said to stay away from, or is that someone else? I don't remember.
  5. willowbilly3
    willowbilly3
    from Sturgis
    They are out of Oklahoma city. I have never bought anything from them. I got thier catalog at the last swap meet in Arlington. They come with a shitload of repro stuff. They have different catalogs for other models too but I only got the A one
  6. scotth
    scotth
    from Austin, TX
    Looks like speedway has them too (scroll to bottom) Not sure if that's the same size though. Please post what you find out, I need a set too.
  7. 41ChevyTrucker
    41ChevyTrucker
  8. manyolcars
    manyolcars
    [ QUOTE ]
    [/ QUOTE ] Ahhh, Fresh Meat!! Go ahead and buy from Obsolete in OK City, then you can join the rest of us who have been screwed by their lousy parts and even worse treatment. And beware-Dales Manufacturing is the same guy.
  9. TikiTodd
    TikiTodd
    I ussually take some half inch round stock, tap the ends, heat it up with a torch and bend it into a U-bolt. takes about 10 minutes...
  10. scotth
    scotth
    from Austin, TX
    I read on somebody's post on here (a rear kick-up howto or something) where they cut the heads off of some bolts and welded the shanks to the crossmember. It wasn't pretty, but looked pretty stout.
  11. Paul2748
    Paul2748
    Snyders Antique Auto Parts. 8.35 each, nuts extra at 3.95 a set. Good products and service
  12. silent rick
    silent rick
    are there any local spring shops around? they should be able to bend some for you. ifn they have the right die.
  13. finkd
    finkd
    U- SUCK and i told you my car will be faster. specially without those bolts.
  14. Thanks folks. You have been a big help!
