Technical u-bolts
Discussion in 'Traditional Hot Rods' started by locknar, Nov 30, 2013.
  1. locknar
    locknar
    from Surrey
    how tight do you go on rear axle u-bolts. I read earlier that the axle tubes are thin, but can you overtighten and deform the tubes?
  2. F-6Garagerat
    F-6Garagerat
    I know banjo axle tubes are not real thick and can warp if you weld on them and you're not careful. Most of the stuff that is not a banjo but would still be used on a period hot rod (olds, Pontiac, 9" ford) would be thick enough that it would take a lot to damage them. Now, if you're talking about some S-10 **** or something similar, well, you're in the wrong forum anyway.
    What axle exactly are you talking about?
  3. Fenders
    Fenders
    Uh, I've got an S-10 rear axle, and I welded the four bar brackets to it....
    Maybe I should swap it out for a 9 inch?
  4. F-6Garagerat
    F-6Garagerat
    Hey use what you like. I'm not trying to start ****. This is the "tradional hot rods" forum. That's what I like. That's why I hang out in here. My hot rod has a banjo.
  5. blowby
    blowby
    from Nicasio Ca
    I was a little worried about this myself, on my 8" Ford, so I took a short piece of pipe and cut a couple of half moons to go under the u bolts.
  6. Heo2
    Heo2
    No you cant`the u-bolt will snap Before deforming the tube
  7. squirrel
  8. rusty1
    rusty1
    ...this 55 Chevy car rearend was in a 50 Chevy truck ch***is I got; they didn't use correct saddles and bent the axle tubes tightening the u-bolts.
  9. Heo2
    Heo2
    I take back my previous statement
    I forget to Count with idiot the factor
  10. A factor that seems to increase with each additional year.
    Cosmo
  11. locknar
    locknar
    from Surrey
    thanks for the replies, the photo by Rusty1 was what I was worried about. Squirrel thanks for the torque specs.
  12. Hackerbilt
    Hackerbilt
    The key factor there was they "didn't use correct saddles"...not that the U bolts were overtightened.
    All the saddle pressure is concentrated on a small part of the axle tube.
    It was destined to fail regardless.
  13. blowby
    blowby
    from Nicasio Ca
    Speaking of U-bolts, should they be flattened where they bear on the housing, like a u-joint bolt? Mine, which I think are from a trailer store, are just round.
  14. It's not necessary. The factory did that on many, but the aftermarket on none.
    Don't overthink it.
    Cosmo
