U-joint problem
Discussion in 'The Hokey Ass Message Board' started by 2OLD2FAST, Sep 22, 2012.
  1. 2OLD2FAST
    2OLD2FAST
    from illinois
    After 35K miles, I've had 2 rear u-joints fail. It's a t-bucket -sbc, 4-speed. ford 8" rear. Engine & trans. is 2* down, pinion is 2* up, driveshaft is at 0*. Normal suspension travel is about 2" up/down. Driveshaft is 13" long. Frt. u-joint is still the one I started with. They are the "good" napa greaseable joints. Anyone have any idea why I'm experiencing what I consider to be "early" failure of the rear joint?
    Thanks , dave
  2. Does the rearend wrap any under power?
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    I wouldn't think so , it's a pretty generic radius rod /ladder bar setup [7/8" DOM tubing , heims on the front , clevis on the rear]
    dave
  4. RICH B
    RICH B
    How about the rear yoke, friend had a one that was bent somehow and when the u-bolt was tightened it deformed the cap and this led to a couple of quick failures before he found the problem. Also heard of the same results due the use of the wrong joint which had a different cap diameter.
  5. Engine man
    Engine man
    from Wisconsin
    Only 3 things I can think of are the aforementioned axle angle change under acceleration, a slight misalignment of the rear yoke in the driveshaft or that short of a shaft might need a constant velocity joint. 18k mile average isn't that bad. I've had some that didn't make it 5 miles but the problem was in my right foot.
  6. ELpolacko
    ELpolacko
    You have a lot of change in angle in just for inches of movement from the rear axle. Larger, more robust Universal Joint will prolong the lifespan, but will still go away after a while.
    Most universals are designed for less than 2º of angle change. At higher angles the less power the joints can transfer, so if you're on it and the suspension squats you could see 4-5-6º of angle on the joints, well past their effective range and outside of the torque transmission thresholds.
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    The wear shows on all 4 legs of the cross on the trust side, so I've kind of ruled out yoke derformation . AFA the short shaft, why just the rear joint & not both ??
    dave
    Joint number is NAPA 403
  8. ELpolacko
    ELpolacko
    Did the math, if your suspension squats 2" that puts the universal joints at 10+ degrees of angle.
    Be happy you are getting that kind of mileage out of your U-joints!
  9. 2OLD2FAST
    2OLD2FAST
    from illinois
    WOW , that much !! Thanks guys, guess I'll Quit *****in' .
    dave
  10. mustang6147
    mustang6147
    from Kent, Ohio
    Thats exactly what I was thinkin.
    I bet its like driving on Ice when you drop the hammer
  11. Mr48chev
    What are the symptoms of the failures? Needles wearing into the cross or just going to hell in a hand basket prematurely? Or the cross breaking?
    You do have the correct U joint for the yoke that the rear axle has ?
    You probably have a 369 Joint at the trans but there are several different numbers that work with the Ford 8 inch rear and may be just enough off to cause problems especially if the joint is failing on the yoke side rather than the drive shaft side.
    Going back and reading ElPaloko's comments he probably nailed it and if your rod was a jacked up 4x4 instead you would probably be congratulating yourself for getting 18k out of a U joint.
  12. Cerberus
    Cerberus
    When you measured the pinion angle, was the weight of the car on all four wheels?
  13. Dan Timberlake
    Dan Timberlake
    wear, or the cross material is spalling and pitting?
  14. 2OLD2FAST
    2OLD2FAST
    from illinois
    Yea, The angles are at ride height, on the ground. Failure is bearings eating into the cross.
    As per previous post ... NAPA 403
    dave
  15. racer67x
    racer67x
    I've seen that happen when the straps holding the caps were tightened too much.
    puts kind of a cross hatch across the part the bearings spin on..just something else to think about.
  16. JohnEvans
    JohnEvans
    from Phoenix AZ
    Actually if you are getting a bunch of straight lines dented into the cross journals that normally is a sign of no angle and the needles are not moving as the joint rotates.
  17. 2OLD2FAST
    2OLD2FAST
    from illinois
    Yea , however that would only show wear on strapped crosses, this shows wear on all 4,[preesed in & strapped in]
    dave
  18. 2OLD2FAST
    2OLD2FAST
    from illinois
    The wear lines are about 3-4 "bearing widths" wide.& "slanted" slightly.
    dave
  19. JohnEvans
    JohnEvans
    from Phoenix AZ
    You sure the shaft rear yoke is clocked perfectly with the front one? And 90* to the tube? With angled wear I suspect a yoke alignement issue.
  20. 2OLD2FAST
    2OLD2FAST
    from illinois
    Yep, it's dead-on , fella that did my shaft was very meticulous!!
    dave
  21. ELpolacko
    ELpolacko
  22. Cerberus
    Cerberus
    I wonder if the way your u-joints are phased are causing early wear? On first gen Camaros, GM phased the u-joints 15 degrees of each other. GM did this to preload the driveshaft. The ****** driving yoke leads the rear driven joke, thus the driveshaft is always preloaded. Did GM do this to eliminate vibration to minimize wear? I had a driveshaft shortened and had the yokes phased 15 degrees of each other. The driveshaft shop didn't feel it was necessary, but said they knew GM did it at one time.
  23. 2OLD2FAST
    2OLD2FAST
    from illinois
    Thanks , Elpolacko, As per the pictures, it appears I'm experiencing "brinelling caused by torque!! That I can live with.
    dave
  24. mgtstumpy
    mgtstumpy
    A few extras, the steeper the angle the less life expectancy from the u-joint.
  25. millersgarage
    millersgarage
  26. Engine man
    Engine man
    from Wisconsin
    The rear is where the angle is changing. What does the guy who made the driveshaft say? They usually only put a constant velocity setup on one end of the shaft.
  27. 2OLD2FAST
    2OLD2FAST
    from illinois
    Sadly , the guy who built the driveshaft p***ed , rear is a single joint & the angle changes at the front also??;)
    dave
  28. 2OLD2FAST
    2OLD2FAST
    from illinois
  29. walker
    walker
    Look into either CV joints or double cardon u-joint. These are often found at 4x4 shops for jeeps, as when they are lifted very high their angles become extreme and also have short shaft issues. A double cardon has essentially two ujoints back to back.
    Also, is it possible to lessen your initial static driveline angles by raising/lowering engine/trans and rear axle in order o give you more angle to play with when your suspension travels?
  30. gimpyshotrods
    gimpyshotrods
    Since I have worked extensively in the 4x4 world, choosing a CV style shaft was a natural choice for my driveshaft-up Model A. I have a fixed yoke in my T56, where the CV ***embly resides. The slip splines are in the shaft itself. Works like a charm, in the A, and both ends of my 4x4 rig.
