Uh things growing where they shouldn't be
Discussion in 'The Hokey Ass Message Board' started by roseville carl, Dec 13, 2011.
  1. scootermcrad
    scootermcrad
    Reminds me of a scene in a movie...
    <iframe width="560" height="315" src="http://www.youtube.com/embed/aeRVB2XP19g" frameborder="0" allowfullscreen></iframe>
  2. Eeeeew, like gross!
  3. GassersGarage
    GassersGarage
    I went to a speed shop to buy water wetter. They asked if my radiator was aluminum. I said yes, they said the water wetter will eat aluminum, Purple Ice was a better choice.
    rod1 likes this.
  4. lippy
    lippy
    from Ks
    Carl, I keep after you guys....alky, NO WATER. :D I know, I know, shut up Lippy. LOL.;)
  5. lippy
    lippy
    from Ks
    That looks like caviar on a lump of vomit...
    LMAO.:D
  6. ssimpala
    ssimpala
    After reading all this, it's got me worried. I'm running Redline water wetter with aluminum heads and radiator. Should I be concerned?:eek:
  7. need louvers ?
    need louvers ?
    Sacrificail anode is the answer for this deal. I once had some one much smarter than my self explain to me why distilled water does this when exposed to aluminum, but half way though the explanation he used the word "atoms" or "electrons" and my eyes glazed over. Suffice to say, I had the same problem with my aluminum heads and radiator in the Plymouth a few years back after religious use of distilled water. (Hell, we don't even DRINK Phoenix city water, after all, you know what fish do in it!!! Not to mention the crunch from the minerals...)
  8. 64 DODGE 440
    64 DODGE 440
    from so cal
    Iron block+Aluminum plate=Corrosion. Aluminum becomes the anode. The "Water Wetter" apparently makes the water a better "electrolyte". If you could hook a voltmeter to the block and plates you are probably making electricity. Don't sweat the details Carl, you have a "Green" dragster. :D
    As a possible solution if you have the aluminum plates powder coated it will insulate them, but you still have aluminum heads so the best solution is find a non-acidic coolant or fill the block and run the thing dry.
    rod1 likes this.
  9. D_Lazaris
    D_Lazaris
    from So. Cal
    I know people freak out that we don't run water but we have never had a problem. Gas and alcohol.
    My dad has run that engine from 75' with no water. And it still runs strong today.
    (you just have to have longer turn arounds or my favorite.. Hose the engine down!!!)
    Plus your options for blocks open up tremendously when you don't run water!!!
    But I don't know what you got going on over there Carl... Weird stuff is a brewing.. Hope you figure it out. I don't like finding that kind of stuff in engines!
  10. Never2low
    Never2low
    "Anodize; To subject a metal to electrolytic action, as the anode of a cell, in order to coat with a protective or decorative film."
    Anodizing is the gold colored electricly adheared coating that discourages aluminum from corosion. Mainly used in petrolium industry, and the aviation industry. Worked for machine shop that did both, and most (if not all) of the parts were finished this way.:)
  11. lippy
    lippy
    from Ks
    There ya go Carl, Lazaris, 64 dodge and me say no water and nitro would be fine.:D
  12. roseville carl
    roseville carl
    Now you guys want me to have parts all over the track huh?
    I will have to slowly work up to the "juice"...............
    looks like sac anode will be put into this engine........
    as I have ideas on kooling between rounds..........
    ps still love your avitar Lippy.........
  13. Deuces
    Deuces
    Looks like last year's science project... :eek:
  14. 64 DODGE 440
    64 DODGE 440
    from so cal
    If you want to cool between rounds you could always set up a small A/C unit and blow cold air through the block. :D
  15. roseville carl
    roseville carl
    doin something similar, a heat exchanger made out of an old coleman cooler and a coil of copper with a 12v bilge pump ..........
  16. Hemiman 426
    Hemiman 426
    from Tulsa, Ok.
    Aluminum will do funky things when exposed to different chemicals...
  17. racemad55
    racemad55
    Looks like my favorite-blueberry pancakes !
  18. hotrodladycrusr
    hotrodladycrusr
    When I read the ***le I immediately thought of guys ear and nose hairs....
    I gotta start dating younger guys. :rolleyes:
  19. Fenders
    Fenders
  20. Blackmaria60
    Blackmaria60
    Man I was eating my sandwich when I saw this ****! :mad:
    I'd scrub it with some Ajax and throw it in the dishwasher!
  21. hotroddon
    hotroddon
    Alodine is an international brand name for Henkel Technologies' conversion, anodizing and functional coatings suitable for use on aluminum, magnesium and other non-ferrous alloys. These coatings provide improved corrosion protection and paint adhesion. Alodine covers chrome, non-chrome and anodizing technologies, and serves numerous markets including the beverage industry, architecture, automotive, aerospace, electronics and others.
  22. rustyfords
    rustyfords
    from Conroe, TX
    That's not right
  23. h2omonkey
    h2omonkey
    from vegas
    For those who are mentioning using distilled water, be careful. Pure water (which is what you have if you have true distilled water) is a very aggressive solvent because it can readily absorb things. Example, distilled water can easily absorb carbon dioxide and forms carbonic acid. It will essentially dissolve any metal (especially soft ones like aluminum and copper, hey, components in some engines and radiators!) and form acids. So, distilled water is not the best idea for a cooling system. If your tap water is overly hard, like many areas of the southwest, use water from a softener, if hard water build up is a concern, it can clog up an engine just like your house pipes only faster because of the heat.
    rod1 likes this.
  24. 64 DODGE 440
    64 DODGE 440
    from so cal
    Denise, you just made me spray coffee on my monitor.:p Made my day with that one. Stick with the geezers, old age and treachery will beat youth and enthusiasm any day.:D
  25. roseville carl
    roseville carl
    x2 Denise.............
  26. spooler41
    spooler41
    Hay man, just throw a quart of bleach in it,and be done with it.
    ...........Jack
  27. Simple.
    Simple.
    from Troy, MI
    That is correct!
    I bought some Alodine 1201 "chemical coating for aluminum" from Henkel industries to coat the cases on my Triumph motorcycle project. Worked great and I did not have to put it in the oven after as stated above. Just had to wash them a couple times after to stop the reaction. I suppose the oven would help with coating them just like re-blueing a firearm.
    I think I paid 30 bucks or so for a quart, and it goes a long way!
    Jon
  28. Mopar Jack
    Mopar Jack
  29. try putting a small piece of zinc in the block. it will become the sacrificial anode.
  30. As if we need another reason not to drink water. holy snappin' catfish that looks bad.
