Ultra Ever Dry
Discussion in 'The Hokey Ass Message Board' started by tfeverfred, Apr 2, 2013.
  1. tfeverfred
    tfeverfred
  2. 3wLarry
    3wLarry
    from Owasso, Ok
    hmm...very interesting...wonder if it's harmful to humans...toxic?...safe?
    kidcampbell71 likes this.
  3. chevyburb
    chevyburb
    I called the Manufacturer to discuss applications to see if I could use it in Construction applications and was told it didn't hold up to wear issues. It is mainly a waterproofing product per the video demonstration. You can't add anything to it because it won't stick. You can apply it to leaf springs to make them slippery as it will wear off. It looks like a great product with narrow applications.
  4. HOTRODPRIMER
    HOTRODPRIMER
    Did you see the end of the video,,gloves,coveralls and a mask,,,I'm betting it's toxic but I am amazed at the job it does.
    Remember back in the late 50's early 60's? Scotch guard,,,this bumps it up to the 10 power. HRP
  5. tfeverfred
    tfeverfred
    I was thinking it would be great on a car cover. Most car covers are water RESISTANT not water PROOF. Or perhaps a tent for camping.
  6. Fopelaez
    Fopelaez
    I don't know how long would it stand for example if you spray it beneath the intake manifold so the engine oil can return faster to the pan (or coat the crank weights). I'd think it would wear off pretty easy, though.
  7. NickJT
    NickJT
    from S.E. PA
    If nothing else I would apply that to my shirts so spaghetti sauce and pizza just roll right off. Otherwise, here's some cautions and limitations:
    http://arstechnica.com/gadgets/2013...lly-scientific-testing-of-ultraeverdry-in-hd/
    First: Reader discretion is advised
    The Ultra-Ever Dry coatings in their liquid state are based on xylene (bottom coat) and acetone (top coat) and emit powerful amounts of fumes. Applying the coatings to anything inside a house or apartment is absolutely out of the question. Even outdoors, coming anywhere near the stuff requires nitrile gloves and a P100-rated respirator fitted with organic vapor filters.
    Bottom line: if you're planning on getting some Ultra-Ever Dry for yourself and applying it, please take the appropriate safety precautions. Many people had previously indicated that they'd love to spray this stuff all over their bathrooms. I sure as hell wouldn't do that in my house.
  8. HOTRODPRIMER
    HOTRODPRIMER
    Fred,through history they have developed my water resistant products but to my knowledge never a product that is totally waterproof,,
    I remember Copper Naphthenate,,that the military used on tents,,it worked fairly well unless you touched it,,, and had a pretty pungent smell.
    Then silicone has been used along with many different petroleum base materials.
    I don't know what is in this Ultra Dry but I can see many applications,,on has to as If used on concrete or wood,,,is it slick when it is in it's dry stage,,or if it's wet. HRP
  9. Why would anyone need for oil to return faster to the oil pan? Why not just add another half quart or so of oil on the original fill and be done with it, or is the oil being used as thick as mol***es? As far as having oil not stick to the crank, I'll bet if flies off rather quickly when the crank starts to spin. Call me a skeptic if you wish, but show me a real need for the product, not just some engineering statistics.
  10. tfeverfred
    tfeverfred
    If you coated two cinder blocks, how would you stick them together? But then, why coat a cinder block anyway?
  11. You could coat anything that's going to get messy .
    Tools, pans, floors, ...
    Anything you want to stay dry, canvas, cloth, fabric
    Tents and car covers included.
    Release agent for clay, sand, wax, filler forms molds.
    As far as wear issues - a cement chute gets PLENTY of wear.
  12. You'd cost them after they were laid up into a wall No? Coat the mortar joints too
  13. hotroddon
    hotroddon
    Coat them AFTER you build the wall and it would be a perfect anti graffiti coating!
  14. hotroddon
    hotroddon
    There are a couple of Reasons. Smokey Yunick was one of the pioneers of this. The theory is that one of the jobs of the oil is to carry heat out of the motor and back to the pan where it will cool quicker. It also helps keep down the formation of sludge that will also cause heat as well as build up over time.
    Not all engine builders agree on this, but some pretty sharp guys building race engines still do it.
  15. 56don
    56don
    Looks like it would be good to coat the outside of your ba*****t walls before you back fill in so to help keep the water from seeping in.
  16. Roger Walling
    Roger Walling
    When a crankshaft spins at high speed, It envelopes itself with oil and looks like a spinning blob of oil. :eek:
    It's a given that oil will become attached to a spinning crankshaft, adding to its dynamic weight and inertial resistance. In fact, high speed photography reveals that the oil can look like toffee rope wrapped around the spinning crankshaft.
    It does not throw it off like you would think it would. Thus the need for "windage trays" and "crankshaft s****ers".
    I think the best use of Ultra ever dry would be on the underwear of the driver of a AAF/D. :D
  17. Ramblur
    Ramblur
    I could see treating your buddies dipstick and then watching them overfill... :D
  18. Hnstray
    Hnstray
    from Quincy, IL
    Interesting product. Apparently somewhat dangerous to use and not durable in some applications.
    're.....engine oil draining quicker........coating the insides of the engine with Glyptol paint does a pretty job for that purpose.
    Ray
  19. mj40's
    mj40's
    I had to read that one twice. :D
  20. Olderchild
    Olderchild
    from Ohio
    Rumblur that's just cold, i'd do it to my son in a hart beat:D
  21. BISHOP
    BISHOP
    I think applying this to the inside of my doors would work.
    Maybe the bottom of the cab and bed too.
  22. 51 MERC-CT
    51 MERC-CT
    Wonder how much faster a boat would travel if the bottom were coated.
    Maybe just one of those 'speed secrets' destined to be banned.
