Ultra Fast Engine Removal
Discussion in 'The Hokey Ass Message Board' started by taylormade, Aug 20, 2007.
  1. GizmoJoe
    GizmoJoe
    Hey there Panhead Pete and Redneck Smooth...
    The 50th anniversary Guinness World Records sites the Fastest time to swap an VW engine to a team of 4 mechanics from Germany who took a motor from a VW bug, installed it in another VW bug and drove it 16ft. 5 in. (5m) in 1 minute 37 seconds Jan.17,1999 in Munich Germany. There were many contests for this task around the world.
    My best time in my VW Karmann Giha was 3 minutes 42 seconds (alone). That wasn't for the fun of it though. I had that thing out more times than I... well.. you get the idea when you have no money to buy new parts.
    FANTASTIC engine to learn on though! My buddies and I learned how to rebuild, hop-up and maintain engines because of those spilt-case wonders. I built my first one when I was 13 out of the parts of 12 engines. Connecting rods bearings? We don't need no stinking.. oh you really need them? Oh. Ok. I'll just take some from here and here and.. yup. Lotsa learnin'!
    I agree with rustynewyorker... here in Nova Scotia that would have been a restored car! Nice find and yah.. quite the torch.
    Hmmm. Maybe I should put an old Vdub mill in my 28 T roadster.. KIDDING!
  2. taylormade
    taylormade
    I was a bit worried about the valve covers, but evidence to the contrary; these guys knew what they were doing. The engine came out in one piece, intact and with those valve covers uninjured. The car was a lot worse than the pictures show. The front of the frame was rotted off and the front suspension was flopping. Rust holes in both bumpers and the lower third of the body was mush. The grill was badly bent but probably savable. Bottom line – I bought the motor, not the car, and the guy didn’t want to mess with taking it apart or sorting out usable pieces. I even offered to hang around and take off the good stuff and put it up for sale cheap, but he dragged the carc*** off and that was it. I wasn’t going to jeopardize getting the engine by making a big deal out of it. He has saved tons of good stuff – some of it I’m going to try and get my hands on!
    "Little Hemi?" This thing looks BIG sitting next to the Wayfarer!
    Check the **** end - fluid drive, soon to be gone.
    Think it'll fit in there?
    <O:p</O:p<O:p</O:p
  3. T-Bone
    T-Bone
    Er...I thought bare ***ties were a no-no on the HAMB....
  4. 72sst
    72sst
    Can you say Deliverance?
  5. Boynamedsue
    Boynamedsue
    I have that same shirt, but i dont wear it when i use a torch. speaking of which where the hell do you get a torch that big.
  6. Mudslinger
    Mudslinger
    Hell I have shorts like that hahaha
  7. Stupid question of the post: If you had to replace one of those covers, what kind of dough would you be looking at?
  8. taylormade
    taylormade
    Depends how lucky you are. I just saw a beat up, non-embossed set go for $200 on Ebay. Jack knew how much I wanted those covers - the whole operation looks a lot worse than it really was, banjo music or not. I don't think this engine was ever touched while it was in the car. Most junker engines I've seen are pretty dinged up. This one is dirty but straight. Having said that, it may be frozen solid.
    RT
  9. Those dudes have probably done this a time or two before ;)
    I've swapped a VW engine in about 30 minutes in a gas station parking lot. About an hour for a Honda motor at a dragstrip pit area. Both of those were with a couple guys helping
    My fastest complete V8 SOLO engine pull was 2 hours from driving the donor car into the garage to having the motor and trans on the ground all by myself with hand tools only, no air, no torches, just a sawzall to cut the exhaust pipe.
  10. Al Von
    Al Von
    Those photos are FANTASTIC!! LOL! I s**** cars at home and have a forklift. However, I could NOT get away with doing that. I live on Main Street and the nosy neighbours put up with enough, that would push them over the edge! I do wear a similar outfit when its hot.
    That torch must weigh 25lbs. I feel sorry for the guys I see at the s****yard having to stand there and cut steel all day, any weather, using one of those. I've got to pick up a Dodge Caravan this morning, the owner REFUSED to take anything for the car. I'll be chuckling all day thinking of those pics.
    I would like to figure out how to pull motors quickly, though. If I pull the engine I don't need a ***le to s**** the car and the motor brings more $$ if separated. But its only worth it if I can do it quickly!
  11. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Check the crank......no dampeners on them dodges.....trust me..I have gone thru 3 already searching for a good one.
    He-man stuff fo sure!
  12. When all else fails and/or speed is the issue, use the smoke wrench.
  13. You mean the "blue wrench."
  14. Mudslinger
    Mudslinger
    no no the hot wrench.
  15. Is that what they call it down there? Interesting. I meant to write, 'smoke wrench'.:)
  16. NYCDrums
    NYCDrums
    Agreed. Hide your shame.
  17. ZZ-IRON
    ZZ-IRON
    from Minnesota
    My buddy got a motor & trans out quick. Hanging from a loader like a Marlin
    Blew the bolts off with the hot wrench & a shake
    The sub frame hit the ground & the Camero lost it's Heartbeat of America
  18. Turbo26T
    Turbo26T
    Thats not a big torch....
    This is a big torch...!!!
  19. powhttrash
    powhttrash
    from omaha NE
  20. Ebbsspeed
    Ebbsspeed
    It's called the fire wrench at my shop.
  21. In that case I'm glad I grabbed one out of the back of a '49 Olds last fall before they could crush it. Why there was just the one in there by itself, who knows.
  22. junkyardjeff
    junkyardjeff
    That reminds me when I pulled a trans out of a 59 olds,the yard owner flipped the car on its side and we removed all the bolts by hand and then pulled the motor and trans. We had to bust the block to get at the convertor bolts and I wish we would of used one of those long torches,where can one of those torches be found as I want one. Jeff
  23. hoof
    hoof
    Oh God!! I haven't laughed like that in a while,
    Thanks,
    CHAZ
  24. Kirk Hanning
    Kirk Hanning
    Or is it called
    "The Detroit Credit Card"
  25. Mercmad
    Mercmad
    from Brisvegas
    I bought one....Allegedlly it was 283.A number check showed it to a 365/327..No intake,smashed dizzy,full of water etc .$350..in 1973:(
