UltraSonic Cleaner
Discussion in 'The Hokey Ass Message Board' started by oj, Aug 2, 2011.
  1. oj
    oj
    I just got a heated ultrasonic cleaner and not happy with the results. I've been using water with some '409' in it. What do you guys use?
    Thanks oj
  2. Watcha cleanin'?
  3. jcmarz
    jcmarz
    from Chino, Ca
    Nothing beats good old fashioned elbow grease!
  4. oj
    oj
    I want to throw carbs in it.
  5. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    Mineral spirits. Carb cleaner, parts solvant. Happy as hell with mine.
  6. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    Use the carb cleaner you can buy in a bucket. Don't let your carbs stay in it too long, they will disolve.
  7. carbking
    carbking
    There are different quality ultrasonic cleaners.
    We use Dawn dishwater soap most of the time. For REALLY dirty carbs (maybe 1 percent of the stuff we see) there is a VERY expensive (like $200./gallon) commercial cleaner. The Dawn does a nice job most of the time.
    Jon.
  8. oj
    oj
    Thanks for the responses. I bought an L&R T15B, heated and about 3qts. About how long should it take to clean a typical throttle body? How often do you replace the liquid?
    Thanks oj
  9. I use that purple castrol cleaner in mine and it cleans pretty fast.
  10. dickster27
    dickster27
    from Texas
    I use Castrol Superclean with a dab of Dawn and a cup of vinegar. I call it "****ster's brew", it does a great job and don't stink.
  11. RodStRace
    RodStRace
    There was a gun forum where the guy was doing a review of different brews. Can't think of where now, but a search should turn it up...
  12. llonning
    llonning
    I use the same, works great. I do nothing but small engine carbs at the moment and the Dawn seems to do the best for me.
  13. nico32
    nico32
    from fdl, wi
  14. Shaggy
    Shaggy
    from Sultan, WA
    At work we use simple green in them, we machine medical parts
  15. chopolds
    chopolds
    from howell, nj
    We clean fuel injectors at work, and related parts. Alconox is what we use, and it works great. Try a lab supply place to find it.
  16. I have been using 50/50 water/vinegar mix for 45 minutes (anymore and you risk the welch plus coming out!) after a 24hr swim in the Berrymans vat and rinsing. The other key is to be sure to preheat the tank to above 130 degrees to "degas" the mix so the ultrasonic can work. And never let a "zinc" carb in for more then a few hours as it will eat them, ask me how I know! Damn it!
  17. N2hotrods
    N2hotrods
    We use purple power in ours. works good on carbs
  18. gearguy
    gearguy
    Tore apart my off topic motor today after it failed a leakdown. Completely gunked up oil control rings and lots of carbon build up. 45 minutes in my $35 E-Bay sourced ultrasonic cleaner with a commercially available general purpose cleaner that cost almost as much as the machine and they were ready for re-use. Die cast aluminum parts were also very clean. The gunked up rings cleaned up to the point of reuseability.
    I'm shopping for a bigger machine as soon as I post this. This little guy paid for itself in one project. I found the concentrated cleaner by searching the net under industrial cleaners. The machine & cleaner are on their way home with my motor builder. After seeing the results he wants to process anything that will fit in the tank. My job: find a bigger tank and order more concentrate.
  19. Godspeed
    Godspeed
    I found this on another website, warning about using some simple greens with aluminum, but others are OK:
    http://www.ar15.com/forums/t_3_7/633271_Simple_Green_and_Ultrasonic_Cleaners_for_BCG_cleaning.html
    Simple Green and aluminum do not mix. Becareful with it on your upper and lower because it will cause embrittlement. They do make aircraft grade Simple Green that will not damage aluminum. The regular stuff is safe on steel and your BCG. I use it full strength in my ultrasonic tank and re-use it a few times too.
    http://www.simplegreen.com/solutions_faqs.php?search_query=aluminum
    SG does make a aluminum safe cleaner, Simple Green Aircraft clean. It doesn't have the dye and perfume either.
    I use Simple Green HD Pro. It is suppose to be ok on aluminum and is cheaper then the aircraft version. From the website Use Simple Green Pro HD in a general cleaning dilution on floors, painted surfaces, aluminum, stainless or polished steel, chrome, plastics, vinyl, canvas, cabinets, counters, stove tops, refrigerators, sinks, showers, tile, and more.
    You can get it at Home Depot.
    SG HD user here as well. And I do indeed dilute it 50/50.. Works great.
