Un-Gunking Flathead Heads
Discussion in 'The Hokey Ass Message Board' started by Baron Von Mike, Jun 22, 2004.
  1. Hi All,
    I've got a pair of aluminum Edelbrock heads I need to clean out. The guy who used to run these obviously lived in an area with hard water. Lots of white, calcium looking stuff inside.
    They'd work as is, but I'd like to clean them out. I'd also like to sandblast them before painting. Two questions:
    1. Any suggestions on how to de-gunk the insides of these things?
    2. When cleaning up the heads by bead/sand blasting, is it also OK to clean the cylinder side of the heads by bead/sand blasting?
    Thanks,
    Mike
  2. I don't really know, but you might give CLR a shot?
  3. Unkl Ian
    Unkl Ian
    [ QUOTE ]
    [/ QUOTE ]
    While it may have worked for some,it is generally not advised.
  4. Bruce Lancaster
    Bruce Lancaster
    Vinegar may well do the job on that white stuff.
  5. magnet
    magnet
    mag cleaner.... serious.. Eagle One brand mag cleaner... and a plastic scrub brush
  6. Flat Ernie
    Flat Ernie
    Tech Editor
    I'm with Bruce - try vinegar before you move on to anything stronger. Poking & prodding with a coat hanger won't hurt either - especially while they're full of vinegar!
    You can sandblast the chamber side for cleaning. Follow it up with a good polish of the chambers though.
    Since these are used, I'd check them for straightness on a flat plate or use something you know is flat/square (good straight-edge). If they're warped, see how much it would take to clean them up & skim them, but be very careful - be sure & check piston to head & valve to head clearance if you skim them.
  7. Bruce Lancaster
    Bruce Lancaster
    Vinegar will remove some deposits cleanly, but some just turn soft and gooey without letting go completely. If this happens, get all the different bottle cleaning brushes you can find and poke then around in there. Also, I would not leave the heads in vinegar over night--it's strong enough to do some damage if it's in the mood for some aluminum for din din.
