unadvertized secrert abilities
Discussion in 'The Hokey Ass Message Board' started by rustdodger, Aug 2, 2010.
  1. falcongeorge
    falcongeorge
    from BC
    Bourbon works good for this too. but you dont have to rub on their gums, just pour it in. Quiets 'em right down.
  2. falcongeorge
    falcongeorge
    from BC
    Wearing pants helps too.
  3. P***ed this on...with proper attribution...to a friend who was having the black streak problem on his camper...here is what he sent me back
    Great catch! I have tried about 10 products to try to remove the black streaks, but NOTHING has worked. Simple Green was the best of everything that I tried, but it also removed huge amounts of oxidized paint, took a great deal of work, and was only very marginally effective. AWESOME really is awesome, and very inexpensive compared to every other product! I found it at the local dollar store, not only in spray bottles, but 1/2 gal. refills. Like you said - spray it on, let it sit, wipe & rinse it off. MAGIC!!!!!!!<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
  4. iwanaflattie
    iwanaflattie
    HAHAHAHA My mom used to tell me that...
    I have no mustache but I can grow a beard pretty fast in some spots,
  5. speedfreek155
    speedfreek155
    I use carb cleaner for wasps also , nuthin's better or faster , plus it doesn't smell as bad as the real bug killer spray . Oh yeah , brake fluid breaks up rust like nobody's business . Used it to free up a seized up engine in my buddys boat .
  6. milwscruffy
    milwscruffy
    Not to mention paper toweling wrapped in duck tape makes a great band-aid !
  7. milwscruffy
    milwscruffy
    Wrap a bondo spreader with sandpaper and use as a sanding block. This works wonders trying to get the small flats and imperfections out on high crown areas ( front & rear fender archs ).
  8. 38Chevy454
    38Chevy454
    Swimming pool acid will remove burned in parallel black rubber streaks on your friend's parent's driveway. It also makes the conrete bright white and his father will wonder what happened; and will not believe the story about cleaning up spilled oil.
    Swimmming pool acid just diluted hydrochloric acid and if you mix it 25-33% in water it works great as rsut remover.
  9. TANNERGANG
    TANNERGANG
    from alabama
    Had a radiator support break about 200 miles from home on a friends car...Fan ate the radiator up...man walks up and sees the water squirting out...walks over to store next door and gets a pack of hot dog buns...he keeps stuffing them in the tore up spot on the radiator till it stopped leaking out water...put the radiator cap on to the first click and we drove it home...radiator shop couldn't beleive it.......always carry a pack of buns on long trips.
  10. Shaggy
    Shaggy
    from Sultan, WA
    It's great for killing bees, just shoot and light!!
  11. wsdad
    wsdad
    Orange hand cleaner will take out the worst dirty grease and oil stains from jeans, carpet, upholstery, dogs, tents, ties, wedding dresses, and the bathtub.
  12. hotskins
    hotskins
    from Justin Tx.
    Ill have to tell my son that one!
  13. stainlesssteelrat
    stainlesssteelrat
    from ms
    pvc cleaner mixed with old gas will get you to a gas station if walking is out of the question.
  14. vg62truck
    vg62truck
    Elax or any laxative will make your sneezing from allergies stop
