unadvertized secrert abilities
Discussion in 'The Hokey Ass Message Board' started by rustdodger, Aug 2, 2010.
  1. tomcat46
    tomcat46
    Cleaning a couple of old Offy intakes last weekend, I tried Simple Green and Gunk Engine Brite (regular spray, foamy and Gel). The Simple Green, regular household strength straight out of the spray bottle, cleaned up the really crusty manifolds better/easier than the Gunk products.
  2. greazy john
    greazy john
    smoking a big nasty cigar wiil get unwanted people away from you lol
  3. 49ratfink
    49ratfink
    if you mist your head with WD-40 your hair will be soft as a babies when you wash it.
    found that out when I helped clean a Baja1000 race truck after the races. the ch***is is all bare metal, and we cleaned it with WD-40 and scotch brite pads.
    try it. the chicks will dig you.
  4. highboy_04
    highboy_04
    from Kansas
    you know simple green specifically says to not use it on vinyl..........
  5. wingman9
    wingman9
    from left coast
    Thanks for the tip. I can use it next time I get some contract work. :D
  6. Russian
    Russian
    Used motor oil cleans your greasy hands better then soap
  7. 49ratfink
    49ratfink
    cheese is good for getting grease off your hands.
    think about it... it is time for lunch and you scrub your greasy hands with boraxo and a brush, you go inside to make a samich, and end up with a grease stain on your cheese.
    I figure grated sharp chedder would be the best.
  8. fbama73
    fbama73
    Cheap, lanolin based hand lotion makes a great cutting/tapping fluid. In addition to being cheaper than stuff like Tap Magic, it does fine on steel or aluminum.
  9. willy3486
    willy3486
    from tennessee
    Oven cleaner will remove the adonizing coating off aluminum trim. I hammered out and smoothed out my trim first. Then I sprayed oven cleaner on it and let it set. I then washed it off and used wet/dry fine grit sandpaper with water to smooth out scuffs. I then found out the silver polish wadding as its called at walmart will polish it up better than any aluminum polish I tried. I did that to my trim and it looks new.
  10. carcrazyjohn
    carcrazyjohn
    from trevose pa
    starting fluid for decal adhesive remover ...
  11. Murphy32
    Murphy32
    from Minnesota
    ...I've been using this one for years !:cool:
  12. willymakeit
    willymakeit
    Put liquid dishsoap on your hands, add sugar [abrasive] then rinse with water. Works like pumice.
  13. Nick Flores
    Nick Flores
    Cracking an egg into a busted radiator has gotten me home once or twice...
  14. gimpyshotrods
    gimpyshotrods
    Just don't be cuttin' in on my territory.;)
  15. koolkemp
    koolkemp
    Black pepper also works well for this.....
  16. TBone69
    TBone69
    from NJ
    WD40 as a starting fluid, Bug-n-Tar remover
    Windex with bleach kills bees dead!
    Pledge with lemon to clean/shine up old toy trains. Just dont use on decals.
    Chewing gum to plug small radiator leaks
    First Aid tape to fix small pinhole leaks in radiator hose
  17. coolbreeze1340
    coolbreeze1340
    from Indiana
    Lime to help a body ....... opps wrong website!
  18. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Barbecued chicken gets the car grease out from under your fingernails, and tastes great!
  19. Snarl
    Snarl
    WD40 works good for getting really greasy hands clean without drying them out...
    WD40 works good for removing sticky residue from decals, etc...
    Brake fluid will kill the weeds growing in the cracks of your driveway...
    Cinnamon in the radiator to plug small leaks (so I'm told)...
    The acid in tomatoes can clean br***, etc...
    SOS pads for cleaning chrome, just don't push too hard. The idea is to get rid of the rust spots, etc...
  20. Paul
    Paul
    Editor
    RainX will take vintage water transfer decals off your windshield
    and strip the color off of modern peel and stick decals too
  21. Paul
    Paul
    Editor
    fine sawdust and bacon grease will quite a knocking motor until the new owner is out of site,
    works in the rearend too although the bacon grease is optional here.
  22. Mumbles
    Mumbles
    How about the old baking soda and water to clean corroded battery terminals trick?
  23. samurai mike
    samurai mike
    cascade dishwasher powder will take the nasty black grease off your hands better than anything.
  24. HomemadeHardtop57
    HomemadeHardtop57
  25. plym_46
    plym_46
    from central NY
    Bon Ami Clensing powder (or Bar Keepers Friend) will get road grim off windshields so your wipers don't chatter. It also works like fine rubbing compound on Oxidized paint.
    Wet the car sprinkle on and scrub, rinse well.
  26. gladeparkflyer
    gladeparkflyer
    big pile of drywall repels friends........
  27. Aaron871
    Aaron871
    And all these years I thought my father was turning his brain on....
  28. El Gordo
    El Gordo
    Now THAT is funny.......Because it's true!
  29. Bloodandmotoroil
    Bloodandmotoroil
    cut open a MRE water activated heating element and sprinkle it on those baked on dead bugs then use a mist gun and mist it with water , wait about 30 seconds and wipe off and presto you got clean paint and a burned hand.
  30. Aaron871
    Aaron871
    Air-soft BB's in your tires will balance them at speed.
    Rubbing alcohol works the same as Rain-X on gl*** and high end gl***es.
    Lacquer thinner is the same as brake clean (There is a company that makes dispensers that you can charge with compressed air).
