unadvertized secrert abilities
Discussion in 'The Hokey Ass Message Board' started by rustdodger, Aug 2, 2010.
  1. AG F/C
    AG F/C
    160 degree oven in your kitchen works great to increase the gloss and durability of rattle can paint.
  2. convx4
    convx4
    Use scotch brite pads with normal dish soap to clean your greasy hands.
    Even under the nail and eponychium area.
  3. rustdodger
    rustdodger
    Roofing works eqully well if not better! Great stuff guys keep them coming!
  4. Gus68
    Gus68
    from Minnesota
    Really really REALLY fine gravel (like the stuff on top of a gas tank thats been in a car for years) works great to quiet a belt thats chirping or got antifreeze on it. Would think tal*** powder might work as well, just never tryied it.
  5. Smokin' Joe
    Smokin' Joe
    Now that's wierd... This afternoon a friend of mine told me of that same trick. Actually I walked up on him as he was spraying a red mixture out of a squeeze bottle onto some casters. I asked him what it was and he said 50/50 mix of ATF & Acetone. He swears it's the best penetrating oil he's ever used.
  6. gtkane
    gtkane
    Vaseline works great to hold check balls in place when ***embling an auto transmission....and co-workers leave you alone when you pull a jar of it out of your toolbox!
  7. ^^^Used to use that one a LOT back in Hawai'i to help control rust as well!^^^
  8. steveo3002
    steveo3002
    from england
    a dab of superglue if you cut yourself ..seals the cut instantly
  9. uc4me
    uc4me
    Used motor oil (mixed with your choice of oil based stain, if you want a certian hue) works great for treating wooden fences/fence posts, etc and it kills the gr*** near the fence so you don't have to use a weed eater so you spend less time with lawn maintenance and more time in the shop
    also, lacquer thinner kills bugs DEAD
  10. you did mean post application..yes?:D
  11. samurai mike
    samurai mike
    br***o polishes aluminum even though it say not to!
  12. chevy57dude
    chevy57dude
    Gasoline applied to poison ivy rash dries it right out and kills the itch. Wait 1/2 hour before smoking! Muriatic acid takes rust off parts, soak them in it, neutralize with water and spray right away with WD-40 to keep from flash rusting.
  13. adamshumard
    adamshumard
    zit cream will take 3 day old spaghetti sauce stains of your newly upholstered white vinyl seats. Thought the world would end that day then a budd said use something with benzyl peroxide. Worked in about 4 hours. The only thing that saved my room mates was the thought that blood may stain worse......
  14. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  15. Mix orange juice and sparkling water together. It doesn't work for removing paint but makes an excellent drink that tastes better than straight orange juice and has less calories. Nice result, better taste and less calories. Now if I can just find something to mix with a hot fudge sunday to make it taste better and have less calories.
    Charlie Stephens
  16. greensheads
    greensheads
    Go to a used appliance store and get an old self cleaning oven. put your parts in and turn on the self cleaning cycle. Itll bake off every bit of carbon/paint whatever on things like cylinder heads. Be careful what you put in there though. Things that are tempered (like valve springs) or thin stuff will be ruined.
    NOTE: Don't use your wife's oven for this.
    An old portable dishwasher makes a great "Jetwash" cabinet for non rusting parts. it really works good if you have access to hot water. dishwasher soap cleans stuff really well.
    NOTE: Again, using your wife's dishwasher = bad idea.
  17. Vintage gl*** headlight lenses (pre-sealed beam) and gl*** taillight lenses clean up really nice in the dishwasher with Cascade.
  18. slickschoppers
    slickschoppers
    from Iowa
    that one doesn't count.... OK... it DOES.. but WD stands for WATER DISPLACEMENT. that is actually what it is INTENDED TO DO.
  19. krackerjack88
    krackerjack88
    from Fresno,Ca
    A new roll of Duct tape makes a good cup holder.... :eek:
  20. Ruiner
    Ruiner
    Gojo hand cleaner removes grease on an engine...just rub it all over the engine, wait half an hour or so and pressure wash it off...found that out by accident when the glob that fell off my hands while cleaning my hands up wound up being the cleanest spot on the motor after using regular foam engine degreaser ****...I've also used trans fluid to refill a brake system after losing a brake line as a "get me home" fix...the upside was it polished the bores of my wheel cylinders pretty nicely...
  21. zmcmil2121
    zmcmil2121
    If you get your new carpet wet, or any carpet for that matter, put a heavy coat of baking soda and remove after and hour or so. Just be warned that with very few colors, it will whiten. :D
    Plus my personal favorite. Super glue as a band aid. No matter how big the cut, grab yourself some super glue.
  22. TBone69
    TBone69
    from NJ
    And it took them 40 tries to get a formula that worked, hence WD40. At least thats what the NASA tour guide told us.
  23. 39 All Ford
    39 All Ford
    from Benton AR
    Paint remover (Aircraft Remover) works really, really, well as a parts cleaner.
    I like it for cleaning up an engine before dis***embly for starters, then again with a wire brush before painting.
    IMO, this stuff is the best thing for folks who can't or won't get the parts hot tanked.
  24. theHIGHLANDER
    theHIGHLANDER
    I'm doing some running board trim. The OEM washers are "cups" so the threaded bosses in the castings will pull down tight to the rubber/sheetmetal. As usual the last folks that worked on the car didn't think to save em all. I used 5/8 cup style freeze plugs and punched a hole in em with a Whitney punch. Problem solved. Don't ask me how I thought of it...
  25. Strange Agent
    Strange Agent
    Cat litter is great for abosrbing oil/fluid spills at the shop.
  26. Cymro
    Cymro
    Biological Washing powder in warm water will soak off gunge on alloy rocker covers and manifolds, BBQ grills and oven racks, leave for a few hours a quick rub with a scotchbrite pad and rinse, Washing powder and water will also clean the gunge from the inside and outside of plastic fluid reservoirs, screen washer bottles etc.
    If any of you guys go camping a paste made of washing powder and water smeared on the outside of billy cans etc will prevent the tar in woodsmoke baking on the outside making clean up easier, even after a week or two, (old boy scout trick) just keep the coating as dry as possible when washing out the pots.
    Hand soap (bar) smeared wet on aluminium will turn black at the correct tempreature for annealing.
    Parrafin candle wax with heat as a lubricant / penetrant for siezed threads, also a good lubricant for woodworking tools and prevents pinning with aluminium swarf.
    Chalkboard chalk rubbed on hand files prevents pinning with softer metals.
    Bar keepers friend for cleaning br*** and alloy ( this contains oxalic acid as found in rhubarb as the active ingredient, this is also the active ingredient in "wood bleach")
  27. budrow
    budrow
    I keep a 5 gal. bucket or two of saw dust from the table saw handy for oil spills in the shop. Put it on, let it set, sweep it up and put in the shop stove. That first fire in the fall is easy to start.
  28. bobj49f2
    bobj49f2
    Just a note, oil dry was developed after numerous problems with saw dust being used to absorb oil.
    Another note, if no one has discovered this, plain cheap cat litter is cheaper than oil dry. Same stuff, just in a different package, in a different location. At least in the local farm supply store. Cat litter comes in a larger bag at about 10% cheaper. I buy the big bags for my business, if I ever get audited the IRS is going to ask to see the big *** cat I have in my shop.:D
  29. revkev6
    revkev6
    from ma
    actually this one doesn't count either! superglue was originally designed to close wounds. interesting stuff!
  30. Clean really dirty oily hands using liquid dish soap (Fairy Liquid over here) and sugar - no water. The sugar doesn't dissolve in the soap and acts as an abrasive. Wash it off with warm water once all the cack is s****ped off.
    Strawberry jam over a scratch on a hire car, followed by a drive down a dusty road, covers up the damage and avoids h***le when returning it - this worked great in Rome last month and saved us 100's of Euros.
