Unbushed Aluminum Rods?
Discussion in 'The Hokey Ass Message Board' started by owen_64, Apr 19, 2011.
  1. owen_64
    owen_64
    I took the pistons off of the rods tonight. The first thing that caught my eye is that the pin bore didn't have a bushing. I'm no expert, but everything I've seen so far has had one? I have no idea what the pin material is. I then removed the cap to inspect the bearings. The date on the bearings is 1-85. So I'm ***uming the motor was built in the mid-late '80s. My question is, how long could these rods have ran before going bad without a bushing? I have the tooling to bush it, but I'm thinking I'm probably better off buying a new set. The make of the rods is Waterman(Mech. fuel pump manufacturer). Someone told me that Waterman used to make rods along time ago.
  2. Crazydaddyo
    Crazydaddyo
    I've made 2 stroke rods out of 7068 aluminum that ran over 20,000 rpm that had no bearings on either end.
  3. Beef Stew
    Beef Stew
    from So Cal
    Are they floating pins or were they pressed in? Sorry if that's a stupid or obvious question.
  4. owen_64
    owen_64
    I guess I should have pointed that out. They are floating pins.
  5. alot of modern OHC cars dont use cam bearings in alloy heads and they dont seem to wear out unless theres an oil flow problem. never seen an alloy rod but i imagine itd be ok
  6. owen_64
    owen_64
    In case anyone is wondering what motor I'm talking about, I'm building a 331 sbc injected nitro motor for my slingshot.
  7. Crazydaddyo
    Crazydaddyo
    Full floating pins don't have bushings in the pistons. Why are you worried about the rods?
    Are you going to run this engine on the street?
  8. SimonSez
    SimonSez
    If you don't know the history of the engine, maybe you are better off replacing them anyway?
    [Edit] Even more so, now you mention you are building a nitro engine!
  9. Da Tinman
    Da Tinman
    get new oners, aluminum rods only have so many p***es in them, if you dont know the history of them make wall hangers out of them for sure.
  10. owen_64
    owen_64
    I feel pretty dumb now. I have an old set of top fuel rods. I was watching TV and looked down and saw them. No bushings. I don't know what I was thinking when I was worried that mine didn't have any. The car won't be ran but 3 or 4 times a year. The parts that I have for it won't last to long either. I'm using a stock 327 block (lrg. journal) and a stock forged crank. It's going to be on a lose dose of nitro (40%).
  11. Beef Stew
    Beef Stew
    from So Cal
    makes sense i guess. aluminum is obviously "soft" and acts as it's own bushing or sorts. probably why a steel rod needs a bronze bushing. you don't want to hard materials wearing on each other.
    and i concur on the new ohc engines not having cam bushings. it's just cast iron on cast aluminum now-a-days.
  12. Shaggy
    Shaggy
    from Sultan, WA
    ive heard in the early 60's of people running bonniville with alum rods and NO bearings, summers brothers siezed and engine running that way
  13. Alum rods never had pin bushings. The question will always be: how many cycles have the rods been run. To trust a used alum rod is akin to Russian Roulette. If you know exactly the life history, then you have info for a good decision. If it's a maybe, what is all you're parts worth? So you have several of us that agree on not taking the risk.
  14. dirt t
    dirt t
    Our TAFC 10 runs and we would replace the rods.Thats 10 hard p***es.
  15. Chevy55
    Chevy55
    from Nebraska
    Another vote for hanging them on the wall. I ran a set too many p***es and turned a nice engine into s****. A chunk of the rod got jammed into the cam and stripped out the timing chain. Bent 14 of the 16 valves. Piston came up and put a huge divot into the aluminum head, $400 to repair, ruined the crank, block and oil pan. Bent the cam and ruined the roller lifters. Huge window in the block. Lots of aftermarket rods for sale cheap these days. Buy some!!!!!!!
  16. aerorocket
    aerorocket
    from N.E. P.A.
    Just curious, what type of 2 stroke?
  17. badshifter
    badshifter
    Model airplane engine. Guessing.
  18. ClayMart
    ClayMart
    Somewhere I've got the remains of a Howards aluminum rod that came out of an old A/Fuel motor. The big end had failed but the pin end looked like new. Seem to recall the pin bore still showing the finish from being honed and don't believe there was any oil hole drilled in it.
    Do some of the T/F and F/C guys still change the rods after every p*** like some of them did several years ago? :confused:
  19. Deuces
    Deuces
    Are those the stock 5.700" length rods??? I'd build a length checker but I don't own a bridgeport.. Have them checked for stretch... If they still check in @ 5.700" in length, I'd run them... Also have them checked for hair line cracks using what I believe is called the "ziglow" method...
  20. Deuces
    Deuces
    How about some pictures of those aluminum rods??? Thanks!
  21. michev
    michev
    A 26 year old Waterman rod and you want to run it? Good luck but I would change them.
  22. Deuces
    Deuces
    If the center to center length checks good and no cracks plus good bores.... Yep! :)
