Projects Uncle Elmer's Model "A"
Discussion in 'The Hokey Ass Message Board' started by MISTER TWISTER, Jan 15, 2012.
  1. 1lowbuckrodder
    1lowbuckrodder
    so did you put the plasma cutter to it,,,,,,any new pics???
  2. MISTER TWISTER
    MISTER TWISTER
    Unfortunatly, i had to break down and buy the aftermarket steering arms because the original '40 arms hit the drop in the axle and really restricted the turning radius. Now with the new bolt-on arms i have a good turning radius but the tierod travels farther and made the interference between the tirerod and the crossmember worse. My solution was to trim the back portion of the crossmember and reconfigure the front engine vibration mount.
    So, since I have a really hard time throwing away things, i hung onto the cut off '40 spindle arms. So with the combination of the original model A front mount, 40 arms, and a little cutting/welding/grinding. i had a new mount that clears everything. I thought it turned out kinda cool....
  3. BCCHOPIT
    BCCHOPIT
    That does look cool. I forgot you were keeping the banger
  4. Offset
    Offset
    from Canada
    Great looking car MT. I too like the stance and like the steel wheels as well.
    Best of luck with your project. I am sure it will be really cool when it is ready for the road.
  5. MISTER TWISTER
    MISTER TWISTER
    bcchop, the Banger is the plan for now unless i stumble across a flatty v8 for a decent price, i could be persuaded easily!
    Offset, thanks, The shoes on the car are my buddies, mine will be the same size tire but with 16" wires instead.. Still undecided whether to go with a whitewall or black??
  6. BCCHOPIT
    BCCHOPIT
    I will not do white walls next time.
    I plain to have black walls on steel 16s on my Tudor so then I can swap
  7. MISTER TWISTER
    MISTER TWISTER
    love your coupe. I think it looks good with the whites on it. is it all original running gear? trans/rearend etc..
  8. BCCHOPIT
    BCCHOPIT
    Yes all stock running gear.
    I have almost all the parts for the 5 speed I just don't want to stop driving
    it to do the work. When the tudor gets on the road then I will dig into the coupe.
  9. 1lowbuckrodder
    1lowbuckrodder
    mounts look *****in
  10. MISTER TWISTER
    MISTER TWISTER
    Just got my wheels back Friday from CPC in Suffield, they really turned out great..
    kiwijeff likes this.
  11. 60 ford
    60 ford
    That's going to be an awesome ride.
  12. Grumpy
    Grumpy
    from NE Ohio
    Coming along great Scott!
  13. larry woods
    larry woods
    from venice fl
    No! It would look much better in MY garage! seriously, looks terrific and I agree sometimes less IS more!
  14. Man she sure looks sweet with that stance and those wheels:eek:!
    You're really making me regret getting rid of the fenders on my 31.
  15. MISTER TWISTER
    MISTER TWISTER
    Thanks guys! Excited to get my wheels n tires mounted up for it soon. Just about got the frontend/steering all done then i'm going to move onto mounting a master cylinder and doing some brake work..
  16. nsh57
    nsh57
    Any updates on the A? I'm hoping to see that thing running around all summer.
  17. MISTER TWISTER
    MISTER TWISTER
    Well I took a pretty lengthy break from the sedan but finally getting back into it now. Brakes are next on the list. Here are a few more updated pics..
  18. Gamlebilrokker
    Gamlebilrokker
    from Denmark
    More pics man! Everybody on FB knows this thing is on the road by now, and it's most brilliant! It sits so right that's unreal.
  19. Ray C's son
    Ray C's son
    I can't believe how solid it is for a NE Ohio car. Looking good.
    Kevin
  20. MISTER TWISTER
    MISTER TWISTER
    Thanx fellas! Here's a cpl more up to date pics. My grandpa was loving that ride being a old model A guy himself!
  21. general gow
    general gow
    MODERATOR
    killer little car. i love it!
  22. Malcolm
    Malcolm
    from Nebraska
    Man that looks great -- and the stance! Very cool!!
    Malcolm
  23. insomniacshotrods
    insomniacshotrods
    One of the best looking sedans ive seen. Perfect stance wheel/tire combo. Neat idea on firewall color, really makes it pop. How does it ride? Does the tire hit the fenders ever?
  24. roert
    roert
    from weilheim
    Hello
    I've seen your car on facebook do you sell it?
