under dash antenna ?
Discussion in 'The Hokey Ass Message Board' started by olds vroom, Mar 18, 2011.
  1. olds vroom
    olds vroom
    I read a post awile back were someone used a regular antenna on its side under the dash. Have many of you guys done this and how good does it really work? I'm thinking of doing this in my 41 olds under the metal dash.
  2. wvenfield
    wvenfield
    Doesn't work for squat............IMO.
  3. J&JHotrods
    J&JHotrods
    FWIW, I had an old blazer and mounted the antenna to the outside of the framerail. Reception wasn't quite as good as the stock fender location, but it did work ok.
    JM$.02
  4. tommy
    tommy
    My roadster came with one mounted horizontally under the running board. It worked reasonably well. I never did any testing for distance but it picked up everything around here. It was FM. Inside the car might not be so good. A lot depends on how far from the station that you live. Montana might be a problem but in suburban Wash. DC it's fine:D
  5. 1971BB427
    1971BB427
    from Oregon
    Mine is mounted horizontally inside the trunk area and works great!
  6. Butcher's Shop Customs
    from Paducah KY
    Mine is under the dash in my 54 Chevy, and it works like a charm. Nothin fancy, just zip tied to the defrost duct! And it is FM.
  7. Westerman
    Westerman
    from Cincinnati
    I've installed them under the dash and had no problems.
  8. olds vroom
    olds vroom
    would it be better to use a rubber coated boat antenna?
  9. Just remember to ground the base.....and insulate the antenna
  10. dalesdeadbug
    dalesdeadbug
    from cincinnati
    my 63 convertible has one zip tied under the dash and its a bit hit and miss on reception
  11. demmals7ytriht
    demmals7ytriht
    from Speer lane
    Mounted one underneath the running board on my 41 Ford years back, & wasen't very impressed with the results, I ended up putting a hidden antenna under the headliner, it worked............
  12. krackerjack88
    krackerjack88
    from Fresno,Ca
    It works but isn't as good as said above.
  13. THE_DUDE
    THE_DUDE
    I dont run a antenna and I use my Zune as a reciver. It picks up nice reception laying on the seat.
  14. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    I would think that the quality of the antenna would have an effect on how good the reception would be. Also back when me and friends were younger when we would install stereos in are newly purchased used cars we always trimmed the antenna in with radio(remember that). Not sure if new radios have that option anymore or not I have not installed a new radio/stereo in a long time, if it is still an option it does help with reception.
  15. T.L.
    T.L.
    from Colorado
  16. I usually put mine behind the kickpanel inside the A-post. I've never had a problem with reception.
  17. banginona40
    banginona40
    I mount them along the frame rails and they work fine.
  18. ffr1222k
    ffr1222k
    I have used a piece of lamp cord soldered to an antennae plug and it worked fine. It was a fibergl*** car though. I don't know how much difference that would make.
  19. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Go to a bike dealership and look at the dakota digital underfaring antenna. Nice long cable, and can be easily hidden inside the car on the back side of the gl*** somewhere. Pretty good reception. They run about $80 bucks. Ive had several customers run them on bikes, and a few on cars, nobody has complained. This winter I'm putting one in my unibody.
  20. I just have to share this expirence with ya'll!
    Today in the garage we were mounting the radio in the IHC and it has as mentioned in #16 the antenna mounted in the A-post behind the kick panel. As we hooked up the radio it just happened to be on 87.9 FM and it picked up the signal from the FM transmitter that we had hooked up to the Ipod about 10 feet away! I just thought that was pretty amazing, since how powerful can a FM transmitter like that really be?
    So I guess this method works huh?
    Klaus
