Under floor brake boosters
Discussion in 'The Hokey Ass Message Board' started by Hank, Jun 18, 2012.
  1. Hank
    Hank
    from Wisconsin
    Anyone have any issues with va***e brake boosters mounted under the floor? I've been looking at installing one and started to wonder what happens when the peddle is pressed. In the firewall mounted state the booster should draws air in to one side from inside the vehicle. If you mount it under the vehicle it now would draw air from under the vehicle. Not a big deal if the weather is nice. I drive my cars a lot and in bad weather. I'm pretty sure the "air" under the vehicle in the rain or on a dirt road is no good for a booster. Should it be vented back to the inside of the car some how?
  2. birdman42
    birdman42
    no promblems that I know about
  3. shadams
    shadams
    Never even considered that. I will wait to see what others say.....
  4. junk yard kid
    junk yard kid
    hydro vacs were put there from the factory on big trucks and school buses
  5. DoubleJ52
    DoubleJ52
    from Belton, MO
    I've got an under floor setup in my 41 and three years on the road no problems with it.
  6. Hank
    Hank
    from Wisconsin
    DoubleJ52: Do you drive it in rain/winter? The question has come up for a slightly off topic truck I plan to use in the winter and around the farm. On a fair weather car I don't think there would be a problem. Thanks for the input.
    Anyone else have experience?
  7. 1956 F100
    1956 F100
    from Louisiana
    I put the booster under the floor on my 56 F100 and drove it in all types of weather especially in the rain. Never any problems. I believe that the va*** is pull from the intake not outside air.
  8. RICH B
    RICH B
    As I remember most of the ch***is mount Hydrovacs had a remote breather behind the seat in the cab. I know this does not answer the OP's question, which has my curiosity up too.
  9. I wouldn't do it again, as the booster I used (common 7" double diaphram) didn't put out enough to make it worthwhile. It also rusted bad, quickly.
    If you've got power steering, get a HydroVac booster. Smaller, more ***ist, and just better, IMHO.
    Cosmo
  10. MedicCustoms
    MedicCustoms
    I have one in my 26 t no problems, but I live in the south so we don't have alot of snow (so not alot of salt......).
  11. Black_Sheep
    Black_Sheep
    My booster has a nice rubber boot on the brake pushrod. It's been in the rain many times without any problem...
  12. they usually have a gauze breather at the inlet under the boot.never an issue.
  13. jnichols
    jnichols
    I sealed around the pushrod with a cv boot and ran a tube into the cab for the booster to **** air through. You can just see the tube going up in this picture. This is going to be driven in wet pacific northwest winters and I was not comfortable about ****ing water and salty slush through the booster.
  14. DoubleJ52
    DoubleJ52
    from Belton, MO
    Yes I have driven in a hard rain and in 100+ degree heat. Had it out Thanksgiving this last year, about 30 degrees out. My exhaust runs fairly close to it and the M/Cyl, I did make a shield and insulated it with some racecar heat material and have a heat shield (DEI) on the exhaust pipe, and the exhaust is ceramic coated but I did that more to preserve the exhaust. Hope this helps!
  15. Hank
    Hank
    from Wisconsin
    Thanks for the input guys. Just to be safe I think I'll add a vent line that route up under the dash.
  16. RagtopBuick66
    RagtopBuick66
    I'd say unless you were planning on using it like a pedal-powered hippo you should be fine. I'm sure weather was taken into consideration when it was designed by the engineers back in the day.
