Under the firewall/filling the void
Discussion in 'The Hokey Ass Message Board' started by Dave L, May 13, 2013.
  1. Dave L
    Dave L
    from Idaho
    Figuring that Baileigh is all about making stuff out of metal, here is my attempt.
    I was looking under the firewall on the cowl where the body bolts to the frame and the connection for the cowl band is on my "A". I will be running a open hood and that area seems to be a eyesore area. (especially those welds, haha)
    Decided to come up with a solution to fill the void where i still have access to the mounting bolts and cowl band connector.
    Started by making a cardboard template: (actually a couple)
    Seems to fit...
    Then make a metal one from the template:
    test fit and grind, fit, grind, fit, grind fit....
    (switching sides now, cause i forgot to take a picture)
    Decided the lip was not large enough so extended it a tad... (Tad... technical term or a wee bit)
    completed result, the black dots are where I will put some screws so a can remove the cover when i need access.
    Thanks for looking.
    Dave L.
  2. HOTRODPRIMER
    HOTRODPRIMER
    Looks good,,,the devil is in the details! HRP
  3. Jen......
    Jen......
    nicely done
    Jen
  4. hillbilly4008
    hillbilly4008
    from Rome NY
    Good thinkin'
    Should strengthen it too!
  5. falcongeorge
    falcongeorge
    from BC
