1952-59 Ford Undercoating
Discussion in 'Off Topic Hot Rods & Customs' started by welderdave562, Sep 21, 2016.
  1. welderdave562
    welderdave562
    what product do you guys recommend for the undercoating? I just had my inner fenders sand blasted and they are ready for paint and undercoating. I was just wondering if anyone recommends anything? Thanks
  2. buymeamerc
    buymeamerc
    from s.c.,usa
    3m #08881 undercoating(rattle can) best. all the others I've used never dry/stay sticky.
    I'm actually going to use bedliner to "undercoat" mine
    welderdave562 likes this.
  3. DIYGUY
    DIYGUY
    from West, TX
    I primed with rustoleum red and then undercoted. X2 on the 3m.
  4. Kustomline54
    Kustomline54
    Same here, I've used 3m spray
  5. Texas57
    Texas57
    I was painting my undercarriage, so zinc phosphate first, and after por-15'ing, I applied an adhesive promoter, then a paintable water based undercoating that's applied with a shultz-type sprayer that screwed onto the can. I really liked the water based undercoating, it was made in Italy if I remember, but when I went back for some more it was no longer available.
    So, if you are planning on painting the undercoating, make sure it's made to do that. Some are not.
  6. 57Custom300
    57Custom300
    from Arizona
    Guy I got my 57 from said he used that gravel guard stuff that they spray on the lower areas behind the wheels. Don't really know what he used but the stuff is indestructible.
  7. welderdave562
    welderdave562
    Cool thanks for the info fellas
  8. HOTRODPRIMER
    HOTRODPRIMER
    I just went to auto zone and bought a case of rattle can undercoating,worked well. HRP
  9. mikhett
    mikhett
    from jackson nj
    Bare metal,then SPI black epoxy primer, then bedliner.
  10. usley paint with same paint I use on the car.
    On the one I bead blast the under side, but do not dissemble, I use tractor paint from tractor supply add the hardener (mat)
    let dry a coppel day the coat with Trans stare rubberized under coat ($50 gal)
    The oil base tractor paint is around $25 hardener another $28 and a little reducer sticks to everything
  11. JeffB2
    JeffB2
    from Phoenix,AZ
